Len Dawg Posted August 18, 2017 Share Posted August 18, 2017 ???????? Quote Link to comment Share on other sites More sharing options...
TheGageinator Posted August 19, 2017 Author Share Posted August 19, 2017 Just ordered some tires. I had a lead on some pug wheels, but it looks like the seller didn't have them after double checking.... Now I have tires on the way, and no wheels!!! Kumho road venture tires. 27x8.5x14 http://www.ebay.com/itm/192154341374 Quote Link to comment Share on other sites More sharing options...
ferp420 Posted August 19, 2017 Share Posted August 19, 2017 6 Lug rims are everywere cheap for your dissy turn it full advance and back off about a 1/8 and you should be in the sweet spot if you can run full advance with out pinning then go for it its ok as long as your not pinging if your still getting that miss do a full tune up make sure there arent any vacume leaks check your intake bolts make sure nothing is loose make sure your grounds to the body and the engine are good you should have a few different grounds on the body from the motor and from the battery to the body and battery to motor and there should be one directly to the altornator a bad ground can cause sensors to go haywire Quote Link to comment Share on other sites More sharing options...
BratRod Posted August 20, 2017 Share Posted August 20, 2017 Hello, fellow Texan! Excited to see more pics. Quote Link to comment Share on other sites More sharing options...
TheGageinator Posted August 20, 2017 Author Share Posted August 20, 2017 (edited) Thanks for the advice Ferp. I've got the timing set to full advance right now. Running premium fuel, my 0-60 is a tad over 16 seconds.... Pretty badass for thr ea82. Everything under the hood is Brand new. Including a rebuilt engine. It's running great. With the ac on, idle is great because of forced idle increase by ac pressure switch. Without the ac on, it's a tad bumpy, but not so bad. Hey there fellow Texan!! I just got back from the tawakoni area on a camping/wheeling trip on the public hunting land. I'll post pics soon. Edited August 20, 2017 by TheGageinator Quote Link to comment Share on other sites More sharing options...
TheGageinator Posted August 20, 2017 Author Share Posted August 20, 2017 (edited) Doing some gun stuff for the youtubes Edited August 20, 2017 by TheGageinator Quote Link to comment Share on other sites More sharing options...
TheGageinator Posted August 26, 2017 Author Share Posted August 26, 2017 Tires just came in! Check out these beasts! One of my 14inch Peugeot wheels is beyond repair so I cant use the tires until I find one more wheel! I need a 14inch steel wheel. Not the spare. Quote Link to comment Share on other sites More sharing options...
Subaru Scott Posted August 26, 2017 Share Posted August 26, 2017 A good welder should be able to repair your wheel. And if you have a dedicated wheel shop in your area, they may be slightly more expensive but steel wheels are no problem. I've seen miracles performed with aluminum wheels even. Quote Link to comment Share on other sites More sharing options...
TheGageinator Posted August 27, 2017 Author Share Posted August 27, 2017 I was able to repair 1 wheel. The other is beyond repair for sure. I'll post a video link to the wheel repair that I did. It turns out that the really bad wheel is the Peugeot "spare" anyway. So it won't work for me even if I could fix it wish I would have noticed that when I bought it Quote Link to comment Share on other sites More sharing options...
ferp420 Posted August 28, 2017 Share Posted August 28, 2017 They made alot of 14" 6 lug wheels Quote Link to comment Share on other sites More sharing options...
TheGageinator Posted September 5, 2017 Author Share Posted September 5, 2017 Got the tires mounted! I had to use 1 alloy wheel until I can get another steelie Quote Link to comment Share on other sites More sharing options...
jsyme Posted September 5, 2017 Share Posted September 5, 2017 Don't you mean.. you had to use 3 steelie wheels before you get more alloys? Quote Link to comment Share on other sites More sharing options...
TheGageinator Posted September 5, 2017 Author Share Posted September 5, 2017 Don't you mean.. you had to use 3 steelie wheels before you get more alloys? haha, if I could find lug nuts(or wheels), then hell yeah. I love the look of those alloys. I found 4 lug nuts with a taper that was usable on the alloy wheel. the steel wheels just have pretty standard 12x1.25 nuts from the parts store. Quote Link to comment Share on other sites More sharing options...
Al Zhiemer Posted September 6, 2017 Share Posted September 6, 2017 Hi, Did you sort your missfire out? May not be anything but I had a simular problem after fitting new spark plugs, ended up working out that the spark plugs where incorrectly gaped. Re-gaped the plugs to 45 thou and problem went away. Quote Link to comment Share on other sites More sharing options...
TheGageinator Posted September 7, 2017 Author Share Posted September 7, 2017 It's better than it was before. I set the timing all the way advanced, I'm running premium. Tons of power now, but still a bumpy idle. I've just gotten used to it because I can't find anything wrong Quote Link to comment Share on other sites More sharing options...
jsyme Posted September 15, 2017 Share Posted September 15, 2017 yep - the ol' 'fixed-it-by-turning-up-the-radio' trick .. Quote Link to comment Share on other sites More sharing options...
TheGageinator Posted September 15, 2017 Author Share Posted September 15, 2017 (edited) Haha yessir! I'm going to build a new exhaust system soon. I just picked up all the pipe. I am going to order a y-pipe to replace my gutted catalytic converter. Does anyone know what size pipe that peice is made of? The previous owner cut the cat Open an gutted it. Then he welded it shut. It has a horrible sound to it. Edited September 17, 2017 by TheGageinator Quote Link to comment Share on other sites More sharing options...
TheGageinator Posted September 18, 2017 Author Share Posted September 18, 2017 Glamor shot Quote Link to comment Share on other sites More sharing options...
