pstanstill Posted June 26, 2017 Share Posted June 26, 2017 I bought a 97 legacy L, 2.2, auto, 270k. Motor runs , trans has torque bind. Tcu codes show duty c solenoid. I wanted to drive it to see if it was worth fixing the solenoid so I disconnected the rear driveshaft. Torque bind went away but the u-joint is clunking against the differential flange. Is there another connection to the differential behind that bracket it sits in? Do I need to remove the u-joint and if so could you tell me how? I'm a carpenter, not a mechanic. If not for the info on this forum I would never have gotten this far Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 26, 2017 Share Posted June 26, 2017 Unbolt the center flange behind the carrier bearing and remove the whole rear half of the driveshaft. Leave the front section in place. Quote Link to comment Share on other sites More sharing options...
wtdash Posted June 26, 2017 Share Posted June 26, 2017 I see you got the codes but did you try the FWD fuse under the hood to confirm it's the Duty C? If it works and the TB goes away, it's NOT the Duty C it's the transfer clutches (mechanical). If it makes no diff, then it's the Duty C and electrical. Also, have you done the 3 Drains > Refills>>Drives routine to clean out the ATF? With 270K and living in FL, I'd probably just drive it w/the FWD fuse installed if it works? Quote Link to comment Share on other sites More sharing options...
pstanstill Posted June 27, 2017 Author Share Posted June 27, 2017 the fuse was in the holder when I got it, apparently having no effect, ( no fwd light on dash.) I did the atf change and added some trans ex for good measure but no effect on binding. Changed rear diff oil whileunder the car. Thanks, fairtax for the tip on taking the whole thing out. I may eventually do the duty C if I can find a good how-to video on youtube. Quote Link to comment Share on other sites More sharing options...
