Torry33 Posted October 26, 2017 Share Posted October 26, 2017 does anyone know the specs for the rear wheel alinement.had a bad rear bearing on one side and a bent arm on the other.transfering complete assemlys from my parts car.would like to get it as close as possable to keep tire wear to a minimum.thanks! Quote Link to comment Share on other sites More sharing options...
Gloyale Posted October 26, 2017 Share Posted October 26, 2017 The only alignment adjustment on the rears is on the inner pivot of the rear radius arms. Just mark where the eccentric bolt is set. Compare the arms while they are out, they are ussually exactly the same but sometimes new ones a hair longer or shorter. If they are the same, put it back the same. if not adjust. for difference. 1 Quote Link to comment Share on other sites More sharing options...
