carfreak85 Posted November 21, 2017 Share Posted November 21, 2017 Throwing this out to the community for help. I'm looking to buy/borrow/copy the driver used to release the rear wheel bearings from an EA-series trailing arm. I've got two sets of wheel bearings that need changing and I'd REALLY prefer to not use a punch to break these guys free. Any leads you can provide will help. Quote Link to comment Share on other sites More sharing options...
BEECHBM69 Posted November 21, 2017 Share Posted November 21, 2017 I think I remember somewhere on here where somebody modified a hub tool from a 4wd Ford to work. Might poke around and see if that will work for you. Dan Quote Link to comment Share on other sites More sharing options...
DaveT Posted November 21, 2017 Share Posted November 21, 2017 I have one of the official sockets for them. It will work if the nut isn't stuck. For the tight ones, I modified a tool for my air powered impact hammer. Ground the end so it could hit the notch and not deform it. Buzzed it enough to get it to turn, then the socket did the rest. I used by HD Dremel tool to cut the staked edge out, otherwise forget turning it. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted November 21, 2017 Author Share Posted November 21, 2017 DaveT, are you willing to loan out that tool so I can copy it? Quote Link to comment Share on other sites More sharing options...
Sapper 157 Posted November 21, 2017 Share Posted November 21, 2017 Or perhaps DaveT could give dimensions, materials, and pictures so the tool could be accurately fabricated? Quote Link to comment Share on other sites More sharing options...
DaveT Posted November 21, 2017 Share Posted November 21, 2017 The socket one? I think I can make up a drawing later tonight. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted November 21, 2017 Share Posted November 21, 2017 I have one, but it's buried from moving, and I won't have time to look until after the holiday. I know someone just found a socket with the appropriate OD, and cut it out until the 4 teeth were left. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted November 22, 2017 Share Posted November 22, 2017 I think I remember somewhere on here where somebody modified a hub tool from a 4wd Ford to work. Might poke around and see if that will work for you. Dan this. there is a 2 pin socket in appropriate diameter available at most auto stores. I think it is a Ford tool. But it's hte same diameter, and has 2 notches directly across from eachother. It's enough to work. Don't need all 4 notches. 1 Quote Link to comment Share on other sites More sharing options...
DaveT Posted November 23, 2017 Share Posted November 23, 2017 Here is a drawing of the rear wheel bearing removal socket:Subaru Rear Axle Socket.PDF 1 Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted August 3, 2018 Author Share Posted August 3, 2018 On 11/22/2017 at 4:43 PM, DaveT said: Here is a drawing of the rear wheel bearing removal socket:Subaru Rear Axle Socket.PDF Hey DaveT, I sent your drawing to a friend to have him cut it for me and he asked what the thickness of the back wall would be, since it's not on the drawing. Thanks! Quote Link to comment Share on other sites More sharing options...
czny Posted August 3, 2018 Share Posted August 3, 2018 Here's one I made from tool steel yrs ago. Make handle approx 16" OAL with 3" dia. head, 1" wide handle, 1/2" flat stock with 1.375" hole thru round head of handle. Turn round stock to 2.437 OD x 2.062 ID x .250 depth, drill 1.062 hole thru center then mill 4 'teeth' to .250 width, hair over .750" apart to fit nut. Weld this hub to handle. Weld the 2 pieces together with 'teeth' at approx 20* angle to handle. Fit over axle stub engaging nut & apply BFH to loosen nut. Subaru rear axle brg wrench.pdf 1 Quote Link to comment Share on other sites More sharing options...
john in KY Posted August 3, 2018 Share Posted August 3, 2018 (edited) That socket is out there. About 20 years ago I bought a pin socket that was a perfect fit for my XT6. Problem is I can't remember from where or how I seleted that particular pin socket. Edited August 3, 2018 by john in KY Quote Link to comment Share on other sites More sharing options...
DaveT Posted August 4, 2018 Share Posted August 4, 2018 Oh, 1/4" thick would be enough. Be safer to go 3/8" . If you need more torque than that can handle, you'll probably need to go with my custom air hammer bit to break it loose. It is difficult to get enough force holding the socket engaged with the nut when large torque is applied. 2 Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted August 5, 2018 Author Share Posted August 5, 2018 CZNY, that tool looks great! DaveT, thank you! Quote Link to comment Share on other sites More sharing options...
