carfreak85 Posted December 13, 2017 Share Posted December 13, 2017 Does anyone know the overall width of an EA82 power steering rack WITHOUT tie rod ends installed? Quote Link to comment Share on other sites More sharing options...
jono Posted December 14, 2017 Share Posted December 14, 2017 I may be able to help if you can be more specific. Rack ends often called inner tie rod. You want them in the measure or where the rack itself ends and inners screw to 1 Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted December 14, 2017 Author Share Posted December 14, 2017 Yes, overall rack width NOT INCLUDING tie rod ends. Thanks! Quote Link to comment Share on other sites More sharing options...
jono Posted December 15, 2017 Share Posted December 15, 2017 yeah, I saw not including tie rods before you capitalised and under lined it but like i said some people refer to the inner tie rods as rack ends, unknown if that include you ! The actual rack shaft length of my PS unit from EA82 is 605mm and has female thread end so EA81 inner tie rods / rack ends wont just thread up to them by mistake on the assembly line as they made EA81 and EA82 same years, dunno if at same plant. You owe me some hand cleaner for that one 1 Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted December 15, 2017 Author Share Posted December 15, 2017 Hahaha, sorry, just wanted to be clear! It's amazing how easily someone's words or intent can be mistaken when you're reading text. 605 mm, great! Apparently the EJ racks are too wide and throw off the steering geometry on an EA when installed. My mission is to find a quicker rack that could be retrofitted to an EA chassis. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 15, 2017 Share Posted December 15, 2017 605 mm, great! Apparently the EJ racks are too wide and throw off the steering geometry on an EA when installed. . I'd love to see a solution to this as well. I'm wondering if the EJ inner tie rods are shortened such that Rack+inner tie rod width is identical to the stock EA rack+inner tie rod width - shouldn't that then make them identical in terms of steering response? Then you just have to shorten the inner tie rods...? Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 15, 2017 Share Posted December 15, 2017 I'd love to see a solution to this as well. I'm wondering if the EJ inner tie rods are shortened such that Rack+inner tie rod width is identical to the stock EA rack+inner tie rod width - shouldn't that then make them identical in terms of steering response? Then you just have to shorten the inner tie rods...? Shortening the steering linkage will effect how the toe changes through the suspension travel. That's what we're talking about, shortened rods has been done but you end up with bump steer. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 15, 2017 Share Posted December 15, 2017 Shortening the steering linkage will effect how the toe changes through the suspension travel. That's what we're talking about, shortened rods has been done but you end up with bump steer. why is that? i'm having a hard time picturing it. seems like the rack just pushes the tie rod in and out the same on both sides - i guess that's not the case? Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 15, 2017 Share Posted December 15, 2017 why is that? i'm having a hard time picturing it. seems like the rack just pushes the tie rod in and out the same on both sides - i guess that's not the case? On flat ground, yes. But as the suspension travels, the control arm and steering link both move in an arc. If they're not the same length, they will not move in the same arc. I did a quick google search and found this picture. It's a little oversimplified as it shows those arcs above horizontal, but a cars travel is completely below horizontal. And I would illustrate it with the 2 arcs overlapping at ride height....but the basic property is the same Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 16, 2017 Share Posted December 16, 2017 Great, very cool. Thanks. But crack that means we got no options! Quote Link to comment Share on other sites More sharing options...
johnny555 Posted December 16, 2017 Share Posted December 16, 2017 (edited) What about the XT4 rack? It does require fabricating a small bracket and rubber bushing but it's not difficult. Edited December 16, 2017 by johnny555 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 16, 2017 Share Posted December 16, 2017 What about the XT4 rack? It does require fabricating a small bracket and rubber bushing but it's not difficult. Are they a significantly quicker ratio? Theyre 30 years old as well. Last year I had an XT6 rack leaking. Swapped in a used rack - it leaked - got another - it leaked. Aftermaket rebuilds arent likely OEM quality but are a reasonable option. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted December 16, 2017 Share Posted December 16, 2017 What about the XT4 rack? It does require fabricating a small bracket and rubber bushing but it's not difficult. Not really any different. Maybe quicker ratio. Just as hard to find a good one. XT 4cyl is literally just an EA82 chassis with a fancy body. I look for nice 2wd loyales in the wrecking yard. They ussually have the best chance at being good non-leaking racks as they have not been abused offroading. But they are all nearly 30 years old now too. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 18, 2017 Share Posted December 18, 2017 I used an XT rack in my Loyale. It was a direct swap, it was a quicker ratio, but only barely. IMHO not worth the work unless you have to replace the rack anyway. 1 Quote Link to comment Share on other sites More sharing options...
Torry33 Posted December 21, 2017 Share Posted December 21, 2017 i converted my non power ea rack with a power ej rack and you have to mod it a little but mine works great! 1 Quote Link to comment Share on other sites More sharing options...
Gloyale Posted December 21, 2017 Share Posted December 21, 2017 i converted my non power ea rack with a power ej rack and you have to mod it a little but mine works great! You think it's great. But in reality, any time you turn or hit a bump your alignment is going wonky. EJ rack is wider than EA82. your tires are wearing faster than they need to and I can't imagine it cornering well with toe changing as you move through the turn. Quote Link to comment Share on other sites More sharing options...
jono Posted December 22, 2017 Share Posted December 22, 2017 Torry can you detail the mods please and how many miles since you did it? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 22, 2017 Share Posted December 22, 2017 (edited) Does any of this change depending on: 1. which model? 2. if it has EA or EJ knuckles (are they offset differently)? 3. lifts or is the track width difference all chassis - between strut towers? why are EJ knuckles and axles usable when they're also from a wider track width vehicle? i think i know the answers but wondering how you guys would answer. i converted my non power ea rack with a power ej rack and you have to mod it a little but mine works great!stock knuckles or have you swapped? Edited December 22, 2017 by idosubaru Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted December 22, 2017 Author Share Posted December 22, 2017 (edited) The problem, as stated above, is that the EJ rack is wider than an EA rack. This pushes the inner tie rod pivot point out of alignment with the lower control arm's pivot point. The problem with that is that when you drive over a bump, the tie rods and control arm don't travel in the same arc. This difference in travel can introduce a small (or large) amount of steering input that the driver did not ask for, making the car feel darty and hard to trust on bumpy roads at speed. Using EJ axles doesn't effect steering geometry. The EJ knuckles don't move the ball joint or strut, so the only real change is the Ackerman angle, due to the relocated steering pickup on the EJ knuckle, relative to the same pickup on the EA knuckles. Edited December 22, 2017 by carfreak85 Quote Link to comment Share on other sites More sharing options...
Gloyale Posted December 22, 2017 Share Posted December 22, 2017 The problem, as stated above, is that the EJ rack is wider than an EA rack. This pushes the inner tie rod pivot point out of alignment with the lower control arm's pivot point. The problem with that is that when you drive over a bump, the tie rods and control arm don't travel in the same arc. This difference in travel can introduce a small (or large) amount of steering input that the driver did not ask for, making the car feel darty and hard to trust on bumpy roads at speed. This. It's about the relative width of the Inner control arm pivot, and the rack. Small difference might not be super noticeable on smooth roads.....But tires will wear funky over time. Did this mod once on an 86 EJ22 GL my buddy drove the car for about 2 years and always had handling issues, and weird tire wear. Swapped out the rack to an EA82 and it is now fine. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 22, 2017 Share Posted December 22, 2017 This pushes the inner tie rod pivot point out of alignment with the lower control arm's pivot point. thanks for putting up with those questions, that makes perfect sense and isolates (I think) the issue specifically. Quote Link to comment Share on other sites More sharing options...
Torry33 Posted December 23, 2017 Share Posted December 23, 2017 ok i have been running my ej power rack in my lifted gl for almost a year with no abnormal tire wear or handling.and we drive a 70 mph speed limit here in Montana.i changed the tie rod ends to ea ones and had to cut the little bracket off the ej rack that held the lines to move the rubber piece that clamps the rack in place.you need to be able to slide it over a bit to make it fit. Quote Link to comment Share on other sites More sharing options...
Torry33 Posted December 23, 2017 Share Posted December 23, 2017 im not an expert or am claiming this is the right or best way of doing this.i just did it because it was all i had to work with at the time and it has been working for me just fine.i have kids and am concerned with safety.if i noticed any odd hadling i wouldnt have been driving this for long like.maybe its so small i dont really noyice it,i dont know.but to me it does drive very good. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 26, 2017 Share Posted December 26, 2017 When using EJ axles, the inner joints are more compressed than on an EJ car. Some people have reported that they bottom out. Technically using EJ knuckles shortens the tie rod assembly slightly, it's a negligible change when driving straight, but that small change relative to the ball joint really improves the ackermann angle (while turning, the inside wheel turns sharper than the outside). Quote Link to comment Share on other sites More sharing options...
