scoobiedubie Posted December 23, 2017 Share Posted December 23, 2017 Yeah, sounds like you've been exposed to a bit too much lead already. Step away from the keyboard, Mal'right........Your advice is bad, M'kay. It's a sickness in the head. Yours. Quote Link to comment Share on other sites More sharing options...
scoobiedubie Posted December 23, 2017 Share Posted December 23, 2017 let’s see if we can do this free - cut a thin piece of cardboard as a form and then strip some wiring laying around the garage and wrap the cardboard for a free copper gasket?! Sheet copper and copper wiring are two entirely different materials. Since both a gas/air mixture and a coolant mixture flow through the intake manifold attachment point, a copper wire wrap could have dozens of leaks for the coolant into the gas mixture, causing white smoke to come pouring out of the exhaust and the engine to run like crap. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 23, 2017 Share Posted December 23, 2017 Sheet copper and copper wiring are two entirely different materials. it was a joke. didn’t think anyone would take cereal box cardboard and some wire seriously. 3 Quote Link to comment Share on other sites More sharing options...
ferp420 Posted December 23, 2017 Share Posted December 23, 2017 Im not sure of the thickness of the copper i use copper isent cheap you wont be able to get the material for under $12 but copper makes the bast gaskets end of story and being reuse able is a plus when i was making my custom intake i had the intake off 12-15 times so thats almost $200 in gaskets if i used factory gaskets everytime i pulled the intake hence the reusable gaskets time is money yes for sure but in the r&d i was doing copper made way more sence i am retiered so the whole time issue is out the window i just enjoymaking my own stuff and when it works better than whats on the market i get stoked on it i enjoy building stuff i see in the stores and or websites the cerial box gaskets do work just fine ive had to do repairs at sea and they work just fine you cant always go to the parts store sometimes you have to make stuff work the copper wire is a thang though its called ringing the gasket you use coper wire rings around ports mostly used for extremely high boost engine headgaskets the wire bonds to the sheet material and makes one hell of a seal 2 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 23, 2017 Share Posted December 23, 2017 The factory gaskets will not bond to the surfaces that quickly. They could be reused easily if doing manifold R&D. GD Quote Link to comment Share on other sites More sharing options...
impostor Posted December 23, 2017 Share Posted December 23, 2017 Time is money. I can't make a gasket out of anything for $12. That's a little over 7 minutes of my time. You'll learn this as you get older. Your time may be worthless now, but at some point you will want to get something done without it taking forever. The dealer gaskets are excellent and fairly priced. There just isn't a reason to deviate from them at this time. GD Exactly. No need to 'spend a dollar to make a dime.' Quote Link to comment Share on other sites More sharing options...
somick Posted December 24, 2017 Author Share Posted December 24, 2017 I Think its more about the prep and how the gaskets are installed ive never had any issues with any gasket ive used on the intake i make my own and there far from perfect but seem to work as good as factory so far anyway That is correct. Sometimes when you buy a gasket you buy a nicely shaped piece of cardboard. Make your own is the way to go. Quote Link to comment Share on other sites More sharing options...
somick Posted December 24, 2017 Author Share Posted December 24, 2017 Somick, hope you call these things gaskets by the end of this task. Even though they do seal, most refer to seals as round rubbery things, So which is which? Quote Link to comment Share on other sites More sharing options...
DaveT Posted December 24, 2017 Share Posted December 24, 2017 In my mind, seals are things for shafts, like wheel bearing seals, hydraulic piston seals. Gaskets are flat cut from paper, composite, rubber, etc. O rings are round o shaped things. 1 Quote Link to comment Share on other sites More sharing options...
jono Posted December 25, 2017 Share Posted December 25, 2017 maybe a google image search will help you on each term, so too a visit to rockauto, search through catalogue and click on images A shaft seal can have a direction of shaft turn indicated on it in the casting of the rubber/plastic, also its ID, its OD and width an O ring is just an O shape mostly if you cut through it you get an O section look at it. You can buy lengths of it to make some o ring style gaskets too. Our EA82 has an o ring section seal fondly referred to as a mickey mouse seal. That light bulb will click when you see one Quote Link to comment Share on other sites More sharing options...
ferp420 Posted December 25, 2017 Share Posted December 25, 2017 The factory gaskets will not bond to the surfaces that quickly. They could be reused easily if doing manifold R&D. GD Once you compress them and get them hot they stick if they dont get hot they might be reusable but that depends on alot of things and after a few time they wont seal anymore 1 Quote Link to comment Share on other sites More sharing options...
