nitpikker247 Posted January 15, 2018 Share Posted January 15, 2018 It sticks especially in the Cold weather. But after a couple of depresses of the pedal, it goes away. Its starts all over again the next day. 2 Quote Link to comment Share on other sites More sharing options...
montana tom Posted January 15, 2018 Share Posted January 15, 2018 Well .. what is it ? year ? Model? color ? air pressure ? 1 Quote Link to comment Share on other sites More sharing options...
gbhrps Posted January 15, 2018 Share Posted January 15, 2018 nitpikker247, This isn't being nitpikky, but knowing what year, model, mileage and options (manual/automatic) often narrows down where we need to start when diagnosing an issue. Until we have that, its a crap shoot. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 15, 2018 Share Posted January 15, 2018 Does it stick open or closed? Quote Link to comment Share on other sites More sharing options...
impostor Posted January 17, 2018 Share Posted January 17, 2018 Clean your throttle body. 1 Quote Link to comment Share on other sites More sharing options...
nitpikker247 Posted January 21, 2018 Author Share Posted January 21, 2018 Well .. what is it ? year ? Model? color ? air pressure ? Quote Link to comment Share on other sites More sharing options...
nitpikker247 Posted January 21, 2018 Author Share Posted January 21, 2018 2005 Baja sport. Auto Trans. Pedal Only Sticks from Idle position. Quote Link to comment Share on other sites More sharing options...
nitpikker247 Posted January 21, 2018 Author Share Posted January 21, 2018 Clean your throttle body. Quote Link to comment Share on other sites More sharing options...
nitpikker247 Posted January 21, 2018 Author Share Posted January 21, 2018 I sprayed silicone on it. I will be more thorough on the next try. Thanks Quote Link to comment Share on other sites More sharing options...
golucky66 Posted January 21, 2018 Share Posted January 21, 2018 Clean your throttle body. The Baja's all have electrical throttle body's. So if the throttle body was sticking it would have no effect on the pedal. As for the pedal. Get down there and spray some lube in there. It's possible it's sticking from age. Then after you spray it down, work the pedal back and forth with the car off so you can move it the full travel. 2 Quote Link to comment Share on other sites More sharing options...
nitpikker247 Posted January 21, 2018 Author Share Posted January 21, 2018 The Baja's all have electrical throttle body's. So if the throttle body was sticking it would have no effect on the pedal. As for the pedal. Get down there and spray some lube in there. It's possible it's sticking from age. Then after you spray it down, work the pedal back and forth with the car off so you can move it the full travel. Thank you! I will Try that. Quote Link to comment Share on other sites More sharing options...
impostor Posted January 22, 2018 Share Posted January 22, 2018 (edited) The n/a baja is drive by cable. The 255 was the beginning of drive by wire. Edited January 22, 2018 by impostor 1 Quote Link to comment Share on other sites More sharing options...
golucky66 Posted January 23, 2018 Share Posted January 23, 2018 You're right. My apologies. Didn't realize the NA's didn't get the updated throttle bodies. Quote Link to comment Share on other sites More sharing options...
nitpikker247 Posted January 23, 2018 Author Share Posted January 23, 2018 ???? Quote Link to comment Share on other sites More sharing options...
kamesama980 Posted January 24, 2018 Share Posted January 24, 2018 (edited) the 03 baja has a throttle cable (EJ251) later n/a models got the DBW EJ253. all turbos are DBW (EJ255?). That's why I got an 03 NA and not newer or turbo. as for fixing the sticking, make sure there isn't a crack in the housing and then use a dry lube. don't use graphite because it could migrate into the electronics. Edited January 24, 2018 by kamesama980 Quote Link to comment Share on other sites More sharing options...
