05 Impreza Not Starting after Engine Install
Reinstalled engine after doing head gaskets. Its turning over and getting fuel, but not starting. Haven't checked for spark yet  because dont have a helper to turn it over. The cruse control light is on and cooling fans are running with the key on.
Edited by steve56
  • Like 1
Forgot to plug in coolant temp sensor. Pull codes.
First code is: coolant temp sensor circuit high voltage. Second code is: p0700 Transmission Control Malfunction
Great call. The coolant temp sensor was unplugged. Plugged it in and it started right up. Thank you.
Edited by steve56
