Parting out 1982 gl station wagon
-im interested in the 3 subaru badges on the vehicle, the 2 side fender ones and the rear one.
-im interested in both front clear corner lights also.
shipping to 78245 for quote, PM me if needed, thanks!
p.s- to remove the fragile 37 year old plastic badges without breaking it, don't use a screw driver, use fishing wire.
Edited by Subasaurus
Wow. That sure looks like a nice, rust free body.
Somebody really needs to save this. If I was a couple thousand miles closer, I would.
Could you possibly figure out an alternative to crushing it if no one will take it right now? Like maybe putting it back in the field it came from?
  • 1 year later...
@JSIMONIS97 - if the key barrel is locked up and you can’t turn the key but you can pull the key in and out: make sure there is no weight on the steering wheel. If there’s tension in the steering held against the ignition barrel lock you’ll never be able to turn your key.
Simply hold the steering wheel with the tension against your hand (pulling/pushing on the wheel) while you operate the key with your other hand.
If this isn’t the case, your barrel is definitelty rooted. Search eBay for an aftermarket replacement ;)
Cheers
Bennie
