comatosellama Posted March 18, 2018 Share Posted March 18, 2018 Finding different length sway bars for lifted cars is veeeery hard unless you wanna spend the big bucks at primitive. Was wondering what the consequence of using this style link in the front would be. The newer models use them, so I figure the idea can’t be that janky. 7 Quote Link to comment Share on other sites More sharing options...
bratman18 Posted March 19, 2018 Share Posted March 19, 2018 Andersondesign-fab.com sells adjustable sway bar endlinks. Quote Link to comment Share on other sites More sharing options...
comatosellama Posted March 19, 2018 Author Share Posted March 19, 2018 Andersondesign-fab.com sells adjustable sway bar endlinks. For $130.. Quote Link to comment Share on other sites More sharing options...
lmdew Posted March 19, 2018 Share Posted March 19, 2018 As long as the link is there it doesn't make much difference what it is. I'm sure the newer styles would work. Same length side to side and strong. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted March 19, 2018 Share Posted March 19, 2018 (edited) For $130.. You get what you pay for. But either way, like was said above, if it fits, it doesn't matter what it is. Edited March 19, 2018 by bratman18 Quote Link to comment Share on other sites More sharing options...
comatosellama Posted March 19, 2018 Author Share Posted March 19, 2018 You get what you pay for. But either way, like was said above, if it fits, it doesn't matter what it is. Not trying to say ADF isn’t worth it, but I’m in college so $130 is a lot to me. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted March 19, 2018 Share Posted March 19, 2018 Not trying to say ADF isn’t worth it, but I’m in college so $130 is a lot to me. I hear ya for sure Quote Link to comment Share on other sites More sharing options...
Gloyale Posted March 19, 2018 Share Posted March 19, 2018 Why would you need longer links? The swaybar is mounted to the engine crossmember, so it drops with the lift. I've never seen anyone need to remove or alter the front swaybar. Quote Link to comment Share on other sites More sharing options...
comatosellama Posted March 20, 2018 Author Share Posted March 20, 2018 (edited) Why would you need longer links? The swaybar is mounted to the engine crossmember, so it drops with the lift. I've never seen anyone need to remove or alter the front swaybar. Seems that the downward angle reduces the effectiveness of the sway bars, since my rear one definitely doesn’t do the job anymore. A longer link would bring it back to stock angle. My car doesn’t have spacers, just got 05 FXT struts and springs Edited March 20, 2018 by comatosellama Quote Link to comment Share on other sites More sharing options...
Gloyale Posted March 20, 2018 Share Posted March 20, 2018 Seems that the downward angle reduces the effectiveness of the sway bars, since my rear one definitely doesn’t do the job anymore. A longer link would bring it back to stock angle. My car doesn’t have spacers, just got 05 FXT struts and springs doesn't make a damn bit of difference. The sway bar operates on the principal of twist placed on the bar from wheels at uneven position. Nothing about the way the bar operates depends on a link of any excact length, just that they both be attached with an equal link. Unless you feel like it's so short that you are losing down travel, which shouldn't with stock Fozzy struts. Hundreds of folks have done the OB/FOR strut swap/lift without needing new front links. I never have. the rear swaybar is mounted to the body, not the subframe. On Outbacks and Foresters they are mounted lower on a dropped bracket. So that's why the rear didn't work as well. The links are not long enough and limit the "droop" of the rear wheels. Grab a mount bracket set from a Forester or 96-99 Outback. Personally I just remove the rear swaybar on most cars I do lifts on. The rear articulation improves so much. With teh bar on it's to east to get "crossed up" diagonally over an obstacle or staggered dips in a trail. with open diffs, that mean you are not moving. Body roll increases, but that happens anyway just from the lift......If you want it to handle like it's on rails, don't lift it. Quote Link to comment Share on other sites More sharing options...
comatosellama Posted March 20, 2018 Author Share Posted March 20, 2018 Not looking for rails, just looking to settle the car down, if I brake mid corner it feels like I’m gonna flip Quote Link to comment Share on other sites More sharing options...
Gloyale Posted March 22, 2018 Share Posted March 22, 2018 Not looking for rails, just looking to settle the car down, if I brake mid corner it feels like I’m gonna flip you're not Quote Link to comment Share on other sites More sharing options...
heartless Posted March 22, 2018 Share Posted March 22, 2018 Not looking for rails, just looking to settle the car down, if I brake mid corner it feels like I’m gonna flip you shouldnt be braking mid-corner anyway... brake BEFORE the corner/curve, then gradually increase speed as you go through the corner/curve. just sayin... 3 Quote Link to comment Share on other sites More sharing options...
Gloyale Posted March 22, 2018 Share Posted March 22, 2018 you shouldnt be braking mid-corner anyway... brake BEFORE the corner/curve, then gradually increase speed as you go through the corner/curve. just sayin... +1 Quote Link to comment Share on other sites More sharing options...
comatosellama Posted March 27, 2018 Author Share Posted March 27, 2018 (edited) +1 Sometimes you gotta though, and I’d rather not feel like I’m gonna die if I need to do some emergency driving. I’ve got a 97 outback swaybar on the way, hopefully that’ll tighten it up Edited March 27, 2018 by comatosellama Quote Link to comment Share on other sites More sharing options...
scalman Posted March 27, 2018 Share Posted March 27, 2018 why you need that rear sway bar anyway ? i drive without it after lift with better handling then i had with sway bar. at least for me this is better way to feel car on road. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted March 27, 2018 Share Posted March 27, 2018 Yeah, to be honest,I don't run a rear sway bar on any of my lifted cars and I'm lifted more than forester struts. You won't roll it over. It just has more body roll. Quote Link to comment Share on other sites More sharing options...
scalman Posted March 27, 2018 Share Posted March 27, 2018 for just 2'' lift spacers and old struts with old oem spring i dont feel any discomfort or more roll there. with new harder springs you can eliminate both sway bars and drive just fine. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted March 27, 2018 Share Posted March 27, 2018 Sometimes you gotta though, and I’d rather not feel like I’m gonna die if I need to do some emergency driving. I’ve got a 97 outback swaybar on the way, hopefully that’ll tighten it up Yeah that's gonna be exactly the same bar as the one you've got. Quote Link to comment Share on other sites More sharing options...
comatosellama Posted March 28, 2018 Author Share Posted March 28, 2018 Yeah that's gonna be exactly the same bar as the one you've got.Stock Impreza is 13mm http://www.mainelysubarus.com/forums/topic/2976-stock-sway-bar-size-list/ Stock outback is 18mm http://legacygt.com/forums/showthread.php/swaybar-faq-134646.html Cheapest sway upgrade ever. Quote Link to comment Share on other sites More sharing options...
comatosellama Posted March 28, 2018 Author Share Posted March 28, 2018 I’m just trying to get handling at least near my moms ‘17 outback Quote Link to comment Share on other sites More sharing options...
Gloyale Posted March 28, 2018 Share Posted March 28, 2018 Stock Impreza is 13mm http://www.mainelysubarus.com/forums/topic/2976-stock-sway-bar-size-list/ Stock outback is 18mm http://legacygt.com/forums/showthread.php/swaybar-faq-134646.html Cheapest sway upgrade ever. Yes diameter is different but it is the same exact profile, length, shape. Won't change how it hooks up to the links at all unless it's a model new enough to us the ball-pivot links, which I don't think 98 would be. At any rate, you don't need longer links. trying to match handling of a brand new top of the line car with your 25 year old base model may be difficult. Quote Link to comment Share on other sites More sharing options...
comatosellama Posted March 28, 2018 Author Share Posted March 28, 2018 Yes diameter is different but it is the same exact profile, length, shape. Won't change how it hooks up to the links at all unless it's a model new enough to us the ball-pivot links, which I don't think 98 would be. At any rate, you don't need longer links. trying to match handling of a brand new top of the line car with your 25 year old base model may be difficult. Thicker=less body roll= what I’m goin for. Maybe it’s just me but I can’t stand the feeling of my rear end floating in a corner. Maybe I just need to put it back down for the summer. Used to handle very similar to a new mazda3 hatch, now it’s like an f150. Quote Link to comment Share on other sites More sharing options...
comatosellama Posted March 28, 2018 Author Share Posted March 28, 2018 Yes diameter is different but it is the same exact profile, length, shape. Won't change how it hooks up to the links at all unless it's a model new enough to us the ball-pivot links, which I don't think 98 would be. At any rate, you don't need longer links. trying to match handling of a brand new top of the line car with your 25 year old base model may be difficult. And this just leaves me wondering, is ADF selling snake oil with the adjustable links? Quote Link to comment Share on other sites More sharing options...
Gloyale Posted March 28, 2018 Share Posted March 28, 2018 (edited) Thicker=less body roll= what I’m goin for. Maybe it’s just me but I can’t stand the feeling of my rear end floating in a corner. Maybe I just need to put it back down for the summer. Used to handle very similar to a new mazda3 hatch, now it’s like an f150. You're rear swaybar may be limiting the downtravel (since rear is bolted to body, not subframe, so doesn't drop with the lift like front does) Like I said, if you want to keep the rear sway, get the dropped brackets from an Outback or Forester And then learn how to drive a bit different. Brake before corner, nuetral throttle on entry, punch the gas out.....this will help keep the weight shifted to the back through the corner, instead of lurching forward and lifting the back end so much. Watch these guys........now THAT's body roll. ---www.youtube.com/watch?v=GYRQzarBOzo--- Might have to copy and paste without the dashes. Can't get the forum to accept this as a link??? Edited March 28, 2018 by Gloyale Quote Link to comment Share on other sites More sharing options...
