Tireman28 Posted April 16, 2018 Share Posted April 16, 2018 I have 93 ej22 that I race on the round track asphalt. Cuts out at 6500 rpm in 3 rd gear. Need more rpm. Just a little. I need prolly around 7000 or 7100. Any advice? Quote Link to comment Share on other sites More sharing options...
Bushwick Posted April 16, 2018 Share Posted April 16, 2018 If you need more top-end, increase your tire OD by an inch or 2 in height and it should bump MPH up w/o having to messing with ecm. Quote Link to comment Share on other sites More sharing options...
Subaru Scott Posted April 16, 2018 Share Posted April 16, 2018 Look into Speeduino. It's a DIY open-source standalone that you can get into for a couple hundred bucks. Completely tuneable and can be configured to work with whatever sensors and injectors you like. 1 Quote Link to comment Share on other sites More sharing options...
montana tom Posted April 16, 2018 Share Posted April 16, 2018 Hey Tireman; Are they letting you use the fuel injection ? Back in the late 90's I ran a 90 2.2 on a high bank dirt oval, I had to run a carb.... modified an intake and used a holley 500 cfm. I still lost a lot to those ford 2.5 engines on the straightaway but I could hammer them hanging on the bottom of the corners. Great fun.... Bottomless black hole..... I miss it ! Quote Link to comment Share on other sites More sharing options...
L5wolvesf Posted April 16, 2018 Share Posted April 16, 2018 If you need more top-end, increase your tire OD by an inch or 2 in height and it should bump MPH up w/o having to messing with ecm. I agree that changing the tire size would do that, but there would be other consequences. Raising the car an inch would affect the handling; that would be a significant raise in the CG. Also, we don’t know if or how much stagger he runs. We also don’t know what class he runs in so the level of prep allowed is unknown. I would guess it is a “mini-stock” type class and in some places mini-stock runs a spec tire (size and/or compound). A taller tire would also affect his acceleration which is important on starts and restarts. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 16, 2018 Share Posted April 16, 2018 (edited) You could do it with an 20G computer and an Enduring Solutions (ESL) ROM simulator board. We have several on EJ22T's. One making 380 AWHP with a 257 block and 25D heads, and another making 252 AWHP with a stock 22T and a TD05-16G. GD Edited April 16, 2018 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
Tireman28 Posted April 17, 2018 Author Share Posted April 17, 2018 Yes I run fuel injection. It’s asphalt oval and kinda like mini stock yes. My stagger I currently went up to my largest is around 71 3/4. I just need more straightaway power. Feels great coming out of the corners just cuts out about 40 foot too soon. Quote Link to comment Share on other sites More sharing options...
