jono Posted June 6, 2018 Share Posted June 6, 2018 I have the main shafts of two boxes side by side on some cardboard Looking at the cogs to line up with hi lo counter shaft cogs I have on std dr box 19 and 25 teeth My hybrid has 25 and 22 My std 5MT DR is from a 92 wagon. Teeth count First 11. Hybrid 11 Reverse 12. Hybrid 12 Second 18. Hybrid 19 Third 29. Hybrid 30 Fourth 34. Hybrid 36 Fifth 39. Hybrid 41 Both have 3.7:1 diffs Anyone know how to figure ratio of each cog for the two shafts? Quote Link to comment Share on other sites More sharing options...
ausubaru92 Posted June 6, 2018 Share Posted June 6, 2018 Would need to know the number of teeth on the gears they mesh with to work it out Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 6, 2018 Share Posted June 6, 2018 Gear ratios are a lot like fractions/imperial sizes. from memory driven gear divided by drive gear. First should be 3.454:1 - it's been a few years since I've looked into it so that could be wrong (so it'll be 3.545 if I'm wrong above). have fun. I love working on/with gearboxes. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
jono Posted June 6, 2018 Author Share Posted June 6, 2018 I like your handle ausubaru92. No idea where you got that from Next thing iI guess I need to count teeth on the other side.... coming up I've done gearbox repairs and rebuilds before Subaru 4WD 4MT put me off. It is better notneeding to drive gearbox the next day Thought I'd compare the innards of my hybrid 5MT DR AWD EA82 box with standard box also in bits Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 7, 2018 Share Posted June 7, 2018 I've been told the pt4wd ea81 4spd is a nightmare level or two above the pt4wd ea82 5spd... The AWD boxes are so much easier to work on Cheers Bennie Quote Link to comment Share on other sites More sharing options...
jono Posted June 7, 2018 Author Share Posted June 7, 2018 The first Brumby box I took apart I needed the jigsaw to get right size socket inside !! Ally swarf everywhere. Balls n springs pop out unexpectedly. Nightmare. Second box I managed without jigsaw. Quote Link to comment Share on other sites More sharing options...
jono Posted June 7, 2018 Author Share Posted June 7, 2018 Quote Link to comment Share on other sites More sharing options...
jono Posted June 7, 2018 Author Share Posted June 7, 2018 Very tricky sorting pics on this tablet, but think I got some numbers in there to match text in first post. Also found three different size and coloured Speedo drive cogs. Black, blue and white (gone yellow) The white on is smallest diamond to match the larger diameter that drives it via the shaft Quote Link to comment Share on other sites More sharing options...
ausubaru92 Posted June 7, 2018 Share Posted June 7, 2018 I have a part time 5sp and an ej box in pieces on my shed floor. will see if i can get photos tomorrow Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 8, 2018 Share Posted June 8, 2018 So what exactly are we trying to work out here? You're comparing two turbo box ratios that are AWD and pt4wd respectively? Or are you comparing the turbo AWD box ratios to the NA pt4wd box? i hope you're not thinking of mis-matching top and bottom gear sets to get a desired set of ratios. For the EA AWD box this is achieved using phase1 EJ AWD gear sets as I'm sure you're already aware of. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
jono Posted June 14, 2018 Author Share Posted June 14, 2018 I was just comparing visually. Huh, and even that is not gonna reveal that the EA AWD drive pinion bearing ID is one mm different to that of the EA PT 5MT DR ! The parts cat revealed that! Best way for me to compare seeing them side by side I sort of worked out that this AWD dual range EA82 box has the typical hardly noticeable low range 19 and20 teeth on the counter gears. EA low range has 19 and 23 teeth Not intending to swap - get into deeper poo than I am in!! Quote Link to comment Share on other sites More sharing options...
jono Posted June 14, 2018 Author Share Posted June 14, 2018 One was AWD DR the others PT 4WD from carb touring wagon. The other FWD turbo Vortex Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 14, 2018 Share Posted June 14, 2018 Put the good low range in while the box is split... That's Lego too. If running an EJ gearset you need to do a few things first... Cheers Bennie Quote Link to comment Share on other sites More sharing options...
