Dustin06 Posted June 17, 2018 Share Posted June 17, 2018 (edited) Hi guys, so I just had a rod-knock in my 2013 WRX which really sucks and pretty expensive. I'm relatively new to cars, and I have a few things to ask of you guys. Is there any advice on how to save money? Right now the dealership says to buy an engine and have them put it in will cost around $10,000. If you have any tips or information I would really appreciate it. Thank you all Edited June 18, 2018 by Dustin06 better post Quote Link to comment Share on other sites More sharing options...
montana tom Posted June 17, 2018 Share Posted June 17, 2018 Take it south to GD's shop and let him put a new motor in . Quote Link to comment Share on other sites More sharing options...
vtwinjunkie Posted June 17, 2018 Share Posted June 17, 2018 is this a joke? Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 17, 2018 Share Posted June 17, 2018 28 minutes ago, vtwinjunkie said: is this a joke? Probably not, it's happening more and more often. You should read the one on subyclub while it was still up... had a full blown back story and all. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 17, 2018 Share Posted June 17, 2018 Uh.... that's nuts. But it's a typical dealer quote. We can do a lot better for a lot less. About $6,500 for a new engine/turbo from Subaru, and about $8,500 for new engine with upgrades like forged pistons, race bearings, larger turbo, tuning, etc. This is fairly typical. Bring it down to Portland. I'll get you sorted. GD 1 Quote Link to comment Share on other sites More sharing options...
vtwinjunkie Posted June 18, 2018 Share Posted June 18, 2018 (edited) 21 hours ago, el_freddo said: Probably not, it's happening more and more often. You should read the one on subyclub while it was still up... had a full blown back story and all. Cheers Bennie Does it actually work? Sheesh. I need a new ac in my house. Should I crowd fund? Edited to sound less dickish. Edited June 18, 2018 by vtwinjunkie Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 18, 2018 Share Posted June 18, 2018 Doesn't hurt to ask. But I doubt it will work. Banks.... banks are where you get money. GD 1 Quote Link to comment Share on other sites More sharing options...
Mike104 Posted June 18, 2018 Share Posted June 18, 2018 Too bad it's not still under warranty. The local dealer here seems to get overrun with blown BRZ/WRX engines to replace under warranty. Sadly many of them are tuned and had after market equipment on them (both which void the warranty). They remove all of the items before going to the dealer (hard to believe a car with 30k+ miles only has 9 key starts). Since you have already been to a dealer I expect you won't be able to try a warranty claim anywhere else (3yr/36,000 miles?). Definitely get GD to install a rebuilt block (or an upgraded one). He will be less expensive and give you quality work. I guess the issue is getting funding but I don't have any suggestions (creditcard/bank/parents?) Quote Link to comment Share on other sites More sharing options...
montana tom Posted June 18, 2018 Share Posted June 18, 2018 Right now your car is worth little more than scrap metal. If your broke park it. Other wise haul it south and get it fixed correctly.... chances are the dealer would screw it up. 1 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 18, 2018 Share Posted June 18, 2018 (edited) 1 hour ago, montana tom said: Right now your car is worth little more than scrap metal. If your broke park it. Other wise haul it south and get it fixed correctly.... chances are the dealer would screw it up. They might. I've seen that too. At the least they will put it back stock which is just about the same as screwing it up. Forged pistons, Killer-B oil pickup, and a silicone turbo inlet are bare minimum in my opinion for making these reliable. And of course air pump delete. That's a given. GD Edited June 18, 2018 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
