Subasaurus Posted July 2, 2018 Share Posted July 2, 2018 has anyone replaced the radiator on a EA71 with a better performing one that somewhat fits with 2 electric fans on it already from some other brand vehicle? height, width, thickness and size of input/output fits? Quote Link to comment Share on other sites More sharing options...
Subasaurus Posted July 3, 2018 Author Share Posted July 3, 2018 any other suggestions besides the deletion of the mechanical fan and instead having a pair of EA82 Electric Fan's already on there, timing is as much as i can go in the retard way (around 7 degrees) and has a 160F degree thermostat? can't go higher than 65mph for more than a few minutes before that needle begins to climb, but then again the Rev's are at 4,000rpm at that point, im already on 155/90 R13 to decrease Engine RPM, which helped by increasing my speed from 58mph to 65mph... perhaps the waterpump is working too well and not letting the coolant have enough time to cool down when going through the radiator? again, any radiator suggestions? Quote Link to comment Share on other sites More sharing options...
Subaru Scott Posted July 3, 2018 Share Posted July 3, 2018 Sounds like you have another issue. EA71s have more than enough radiator capacity and normally never have overheating problems. If your timing is too retarded it will cause overheating. Too much advance only makes problems when it starts detonating. The fans only come in to play when you are stopped or moving very slowly. Try gunning it with the radiator cap off and see what happens 1 Quote Link to comment Share on other sites More sharing options...
83gl_JL Posted July 3, 2018 Share Posted July 3, 2018 My ea81 has an aftermarket fan that is probably a little smaller than it needs to be as the needle climbs a bit when stopped idling in summer traffic, or creeping around on trails. I am going to install a larger one and if that doesn’t work I might try an oil cooler which should help or at least add a little oil capacity. 1 Quote Link to comment Share on other sites More sharing options...
Subasaurus Posted July 5, 2018 Author Share Posted July 5, 2018 On 7/3/2018 at 3:57 PM, Subaru Scott said: Sounds like you have another issue. EA71s have more than enough radiator capacity and normally never have overheating problems. If your timing is too retarded it will cause overheating. Too much advance only makes problems when it starts detonating. The fans only come in to play when you are stopped or moving very slowly. Try gunning it with the radiator cap off and see what happens the coolant system is actually pressurized since i added a coolant reservoir to the radiator, but having the radiator cap doesn't really make a change besides loosing coolant while going down the road. here's the thing, the vehicle has trouble picking up temperature when its 30degrees outside and never goes higher than a quarter of the temp. in 105 degree weather, my top speed is around 65mph before the needle goes higher than halfway. in 90 degree weather, i can cruise down the highway going around 75mph. im going to install an actual temperature gauge from the autoparts store and see what it reads, perhaps im just being paranoid about the inaccurate 40 year old temperature needle... Quote Link to comment Share on other sites More sharing options...
83gl_JL Posted July 8, 2018 Share Posted July 8, 2018 Summit has a nice one by intellitronix that is made in the USA and lifetime warranty. I bought the voltmeter unit when I was having issues, looks good and works great so far. Quote Link to comment Share on other sites More sharing options...
Subasaurus Posted July 30, 2018 Author Share Posted July 30, 2018 so i got the numbers, looks like right after getting off of the highway and stopped at a light after driving for an hour at 65mph, im reading at 190F on the head of the block, and 165 on the coolant right when it's comming out of the block before being cooled in the radiator, on a hot 4pm day outside at 101F. what's interesting is the 40 year old temp needle is at half when it's 175 on the head and 150 on the coolant. and about 2/3 the way up when it's around 190 on the head of the block and 165 on the hottest point for the coolant. is 190Block/165coolant hot for an EA71? 65mph screaming it's head off at 4,000rpm? Quote Link to comment Share on other sites More sharing options...
