Mill1836 Posted August 2, 2018 Share Posted August 2, 2018 (edited) I have a kit car with a 2.5 motor, 5 speed trans, and I don’t know where the cv axle came out of. The rod is 17 1/2 inches long, 21 spline to the wheel side and 30 spline to the transmission. Can any one give an idea as to what car/year this might have came off of. Any info will be appreciated. Edited August 2, 2018 by Mill1836 Misspell words Quote Link to comment Share on other sites More sharing options...
pontoontodd Posted August 3, 2018 Share Posted August 3, 2018 Assuming it's a Subaru 2.5 and five speed trans, I'd just pick up a front CV axle for something like a 99 Outback, Forester, or Impreza. ABS rings are about all that changed on the EJ axles and you probably don't care. This might provide a lot more confusion than help: http://goworldparts.com/wp-content/uploads/2015/11/Worldparts-CV-Axles_Quick-Specs_May-20151.pdf If you can use a standard Subaru EJ front axle, these seem to hold up well and have more plunge travel than most: http://autoshafts.com/i-23374251-cv-axle-shaft.html 1 Quote Link to comment Share on other sites More sharing options...
Mill1836 Posted August 3, 2018 Author Share Posted August 3, 2018 Thanks for you response. I will get on this today. 1 Quote Link to comment Share on other sites More sharing options...
