17 1/2 in cv axle rod
Mill1836
I have a kit car with a 2.5 motor, 5 speed trans, and I don’t know where the cv axle came out of.
The rod is 17 1/2 inches long,   21 spline to the wheel side  and 30 spline to the transmission.
Can any one give an idea as to what car/year this might have came off of.  Any info will be appreciated.
Edited by Mill1836
Misspell words
Assuming it's a Subaru 2.5 and five speed trans, I'd just pick up a front CV axle for something like a 99 Outback, Forester, or Impreza.  ABS rings are about all that changed on the EJ axles and you probably don't care.
This might provide a lot more confusion than help:
 http://goworldparts.com/wp-content/uploads/2015/11/Worldparts-CV-Axles_Quick-Specs_May-20151.pdf
If you can use a standard Subaru EJ front axle, these seem to hold up well and have more plunge travel than most:
http://autoshafts.com/i-23374251-cv-axle-shaft.html
  • Sad 1
