bork Posted September 30, 2018 Share Posted September 30, 2018 Does any one know what all the small hoses do & can I cap them or union them together? I pulled a filler tube out of a 95 imp L & it only has 1/2"?ID vent tube coming off side near top. I was hoping to use this as the replacement until I saw all the spaghetti around the 99 filler, shown below >>> How does that little box with two hoses work, as the "filler neck shut off switch?" Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 30, 2018 Share Posted September 30, 2018 You will have codes if you don't use the exact same setup that was on the car. 99 has a rear mounted charcoal canister. 95 does not. Completely different evap systems. GD Quote Link to comment Share on other sites More sharing options...
bork Posted September 30, 2018 Author Share Posted September 30, 2018 (edited) I was afraid of that. How does the "filler neck shut off switch work? What does it shut off? Edited September 30, 2018 by bork Quote Link to comment Share on other sites More sharing options...
bork Posted October 5, 2018 Author Share Posted October 5, 2018 Update; got lucky at junk yard for a clean one off a Forester for $20.00, and now I have a happy kid again, not whining about gas fumes, and to a fix for snow melting into filler neck and causing no starts in winter when water froze in gas tank, disabling fuel pump. Quote Link to comment Share on other sites More sharing options...
