Sam1968 Posted November 7, 2018 Share Posted November 7, 2018 My 96 Outback 2.5, hesitates when i have the a/c on , the idle and acceleration is sluggish. i have replace many components and also knock sensor , MAP sensor , clean the IAC, replace the fuel regulator valve and EGR valve. I don't know what to do next , I just bought park plugs wires and plugs . The funny thing is when i turn off the a/c the car runs fine. May be i'm missing something? Quote Link to comment Share on other sites More sharing options...
scar13 Posted November 15, 2018 Share Posted November 15, 2018 It may be normal. Turning on the A/C on a 4 cyl. you can feel the load it puts on the engine. Can you feel an increase in power output when the a/c cycles off and on? If you know someone with a same model car see if you can compare it to yours. Quote Link to comment Share on other sites More sharing options...
Sam1968 Posted November 16, 2018 Author Share Posted November 16, 2018 Thank you very much for your reply. I will check with others and ask if they experience the same or similar symptoms. Quote Link to comment Share on other sites More sharing options...
