So I just bought a 2004 WRX with 146k miles. All maintenance done to it OTHER then headgaskets. So I'm wondering, how long do they last on this year? I wanna save up and replace them, but knowing that its gonna cost quite a bit, its gonna be awhile till ill be able to, and don't want anything to happen.
Thanks!
Share this post
Link to post
my girl's old 2004 they lasted until 190k, but the engine was dead tired and due for replacement at that point also. I just stuck an EJ206 ( cheap ) direct replacement JDM long block in it and called it a day
  • Like 1
Share this post
Link to post
Turbo models don't have head gasket problems. Never have. Those engine often go about 250k. Then they are just shot. Main line journals get too out of spec and they throw rods.
Edited by GeneralDisorder
  • Like 3
Share this post
Link to post
I would agree.
  • Like 2
Share this post
Link to post
Oh okay! Thank you for the reply everyone. Good to hear this. I thought it was gonna be a issue. This is really good to hear. Thanks again! And, when that time comes, should I engine swap it with a original wrx engine, or something different?
Share this post
Link to post
22 hours ago, GeneralDisorder said:
When it goes, you do a hybrid with a 2.5 bottom end, and hybrid forged pistons to use the 2.0 heads.
What do you mean by hybrid exactly?
Share this post
Link to post
Also what would be the cost of that? Or rough estimate.
Share this post
Link to post
It's a combination of 2.0 and 2.5 parts.... thus a hybrid of the two. Cost is typically $6k to $8k depending on many factors. Of course that's "typical". I have customers with over $20k into their drivetrain. Usually making well beyond 500 HP of course.
  • Like 1
Share this post
Link to post
Now is that 6k-8k with labor, or just parts?
Share this post
Link to post
That's parts and labor. That's the general range our invoices fall within for that type of job. Or really any turbo engine replacement/build. Sky's the limit though. HP depends on your budget.
Share this post
Link to post
I would stay away from this type of build.  Yes, it is a path that many folks have taken, but just putting the car back to stock or going with a 2.1L stoker engine are better/simpler options.  I would do a lot of reading before you spend any money.  Connect with a local Subaru engine builder and a trusted tuner and discuss your goals with them.
Share this post
Link to post
We do this ALL THE TIME. And we are an engine builder and tuning shop. I just bought a $100k Dyno-Jet.
With the JE hybrid pistons the compression ratio and quench volume are corrected and the engine is simply a 2.5. We have customers making 375 wheel on this combo with ease. There is NOTHING wrong with 2.0 heads on a 2.5 bore.
A stroker is a TON more work than a stock 2.5 with pistons swapped.
  • Like 2
Share this post
Link to post
Thank you for the reply. Its gonna be a long long time (Hopefully) until I do a full engine swap. But a hybrid is probably what im going with. But I have another question unrelated to this if you wouldn't mind checking your messages. Thanks!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign in to follow this
