EA71 freze plug in head
Mikel
20 mm brass for EA81 and 82. Three per head. Dunno if ea71 the same? And GDs socket suggestion ...use socket that fits inside the cup and that is where to belt it. But loose fit socket of you might get socket stuck as it shrinks snug tight. I think it is 0.15 mm larger than nominal hole size to stay jammed in over all the expanding contracting going on
Edited by Steptoe
