jonathan909 Posted December 20, 2018 Share Posted December 20, 2018 I'd like to have a list of available sizes, but it's surprisingly hard to find online. Best I can see so far is on autozone, but it's a bunch of gifs. Does anyone have it in some more friendly (and printable) form i.e. spreadsheet or pdf? Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 20, 2018 Share Posted December 20, 2018 I can't help with your question directly but, depending on what you're doing....some folks just grind a shim down on the non-contact side. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 20, 2018 Share Posted December 20, 2018 You don't grind the shim, you grind the tip of the valve. 2 Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 20, 2018 Share Posted December 20, 2018 (edited) The thicknesses are shown as a comment in the OE catalog. Although it looks like comments aren't displayed on parts.subaru.com But: http://opposedforces.com/parts/legacy/en_b11/type_14/engine/valve_mechanism/ Now, as I recall, many of the part numbers aren't available anymore, and supersede to the size above or below, so watch that (might be worth paying markup to order at a local dealer to verify that and be able to return if they muck it up). Edited December 20, 2018 by Numbchux Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 20, 2018 Share Posted December 20, 2018 Make sure you are 100% positive on the size you need. 10 out of 10 tech's at the dealer level according to my dealer parts guy get it wrong the first time, and most get it wrong the second time too. Math..... it's a problem. GD 1 Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted December 20, 2018 Share Posted December 20, 2018 Which engines have the shim type adjusters? Quote Link to comment Share on other sites More sharing options...
jonathan909 Posted December 20, 2018 Author Share Posted December 20, 2018 1 hour ago, GeneralDisorder said: Make sure you are 100% positive on the size you need. 10 out of 10 tech's at the dealer level according to my dealer parts guy get it wrong the first time, and most get it wrong the second time too. Math..... it's a problem. GD Not around here, it isn't. But I'll be on the lookout. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 21, 2018 Share Posted December 21, 2018 On EZ30s I grind the back side of the shim which doesn’t contact the cam. I quit working on EJ25Ds since I started doing that - is there a reason that would be less effective on those than EZs? 1 Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 21, 2018 Share Posted December 21, 2018 15 hours ago, GeneralDisorder said: Make sure you are 100% positive on the size you need. 10 out of 10 tech's at the dealer level according to my dealer parts guy get it wrong the first time, and most get it wrong the second time too. Math..... it's a problem. GD Yea, the techs I worked with rarely even tried the math, but we stocked a pretty good selection so they could trial and error to their hearts content. Quote Link to comment Share on other sites More sharing options...
