2002 Subaru outback speedometer question
Is there a way to check the mileage on the gauge cluster out of the vehicle? The car is 2002 legacy outback. Its at the local u pull and I'm interested in the engine in the car because the car was in such good shape aside from the major accident. I grabbed the gauge cluster figuring there's a way to check it. I got part of the dash wiring also.  Thanks for any help.
I always check the car for Oil service sticker or paperwork.
I've powered them up with a 9v battery but it been so long ago I couldn't tell you what connector pins you need to go to.  Do you have the same car?  Could swap the dash into your car.  Other than that you will need the factory wiring manual to figure out + and - circuit.
Ya I looked through the glove box and there was no paperwork. The only interesting thing I found was a GPS tracker hidden behind the gauge cluster.
I think I have the wiring schematic, I wasn't sure if it was that easy. I thought maybe it was somehow tied into the ecu. I had a Ford about the same year was like that.
