January 9, 20197 yr Hi! My names Ivy and I figured I should start a build page for my GL this way I can keep track of everything at the same time sharing it with all of you!! So a quick background on the car..I originally bought this car for $150 dollars out of Truckee CA, the guy I bought it from was building up a 2 door wagon and this was his daily driver while he built that. When I bought it the brakes made a horrible noise, the volt gauge didn’t work, the shifter has insane slop, no rear wiper, and that’s all I can remember right now. It was 100% stock and needed(still does) a lot of little things to make it all good again. It runs and drives, but like I said needs work.
January 9, 20197 yr Author This is the day I first bought the GL. Bought it with 375K miles on it. Unsure if the the original motor or trans all I know. Is it is a 4 speed dual range and an EA81. Edited January 9, 20197 yr by 83subaruGLchick
January 9, 20197 yr Author SORRY FOR THE HORRIBLE PICTURE QUALITY THEY DONT LET YOU UPLOAD GOOD QUALITY SHOTS
January 9, 20197 yr Author Fast forward 3 years from that first picture and this is the day I bought her back. I had sold the car for about a year because at the time I really needed money but I sold it to a guy that let me buy it back which I’m forever grateful. I was the one that put the roof rack and tint on, he did the lug conversion along with quite a bit else I’ll go over.
January 9, 20197 yr Author I hated the Toyota wheels so in about a days time I bought some 15X7 Cragar D windows from summit racing and went and got some 205/60/15 Mastercraft a Glacier-Grips II these are the only aggressive treads I could find in this size and honestly I love these tires so far not loud on the road and get great traction. This csr has no lift I just have the springs turned all the way up for now, a lift is coming soon
January 9, 20197 yr Author Here she sits with the new shoes on!!! Okay so the guy that bought it from me then sold it back did these upgrades: center console\dash upgrade to install a voltmeter that works and a stereo fan shroud(I had installed an electric fan but never made a shroud) block heater(this thing HATES cold mornings and it gets cold here) 6 lug conversion fixed some miscellaneous broken interior trim replaced front seats LED headlights working gas struts on rear hatch
January 9, 20197 yr Author About a week after I bought her back I drove it to Subiefest in Los Angeles from Reno, it did amazing it just overheated a little on the long hills but if you know these cars you know that’s a normal thing. I also had trimmed my fenders and I like the style that we decided to do it because you can’t tell really
January 9, 20197 yr Author This was the other day I drove it up a mountain we have here called Peavine. I flexed her out a little sadly the tire got so stuck in the front fender. I have big plans for this car I should be buying some goodies for it here soon and I’ll keep y’all updated!!!
January 9, 20197 yr Welcome to the forum Ivy! Youve got one of the best colours that Subaru ever brought out! I love that blue and would love to have an MY wagon in that colour too. I’ve got an L series in that colour (or slight variation of). Keep the pics coming! Cheers Bennie
January 18, 20197 yr Author Alright guys, I'll upload a few pictures here in a little bit of the trip as well but this last weekend I took the ol GL on quite a journey on this pretty hard trail to these very remote hot springs here in Nevada called the E Carson River Hot Springs I believe. REGARDLESS while the GL did fantastic now she needs some help before shes safely road worthy again. The following now needs immediate replacement: Tie rods, Ball Joints, Rack and Pinion Boots, CV Axles(front), and all the shocks aren't as important but they have been going out so I think I'm just going to do them now, while I have the rest of the suspension apart. That being said I'm going to do some research as well but should I just go OEM replacements with the shocks and struts? I plan to install a lift kit here soon and I have no desire to change my hubs to 5 lug so I mean that will fit OE because I like my drilled out original hubs to the 6X5.5 pattern Any advice you guys have will be greatly appreciated, like I said after this entry I'm going to do some digging of my own as well. Thank you!
January 18, 20197 yr Author SIDE NOTE: My exhaust also broke off on the passenger side at the heads, the studs actually broke off of the head altogether...not quite sure how I'm going to fix that yet
January 21, 20197 yr On 1/19/2019 at 8:18 AM, 83subaruGLchick said: SIDE NOTE: My exhaust also broke off on the passenger side at the heads, the studs actually broke off of the head altogether...not quite sure how I'm going to fix that yet With a lot of fun... I mean Bennie
January 21, 20197 yr On 1/18/2019 at 1:18 PM, 83subaruGLchick said: SIDE NOTE: My exhaust also broke off on the passenger side at the heads, the studs actually broke off of the head altogether...not quite sure how I'm going to fix that yet Did the stud break off, or pull out of the threads in the cylinder head?
January 22, 20197 yr On 1/18/2019 at 2:18 PM, 83subaruGLchick said: SIDE NOTE: My exhaust also broke off on the passenger side at the heads, the studs actually broke off of the head altogether...not quite sure how I'm going to fix that yet My 87 gl10 stripped the threads in the head but subaru was cool enough to put a second set of holes 180 deg off from normal. The pipe had a rotted hole in it as well so the exhaust shop just cut off the flange rotated to match the second set of holes and welded it back on with a new piece of pipe. I can upload a pic later today if you want. Also as some one who just did tie rods and ball joints be careful with the axles, my driver side popped its snap ring at the knuckle and I had to replace the whole thing. Stupid roll pin.
February 8, 20197 yr Author Evening everyone following the build. I have a few updates!! Alrighty so I have officially ordered all new suspension and that should be arriving any day now so that’ll all be fixed a friend of mine also recently wrx swapped his 93 legacy so he had an OBD1 2.2 sitting there with motor mounts, an air box and a complete wiring harness with ecu. That being said I got an amazing deal on it all and I’m officially going to start the swap process (insert super happy screaming and girly jumping up and down here). I’m no wiring guru so I’m having SJR trim my harness for me. I also bought other little things for my car too that I’ll be installing. I’m so in love with this car I can’t wait!!!
February 8, 20197 yr Author Here’s the new roof rack. And her new spot in the garage for the next little bit while I install and fix some more things!! I’ve been toying with the idea of a snorkel so if any of you guys have more knowledge on ones that work the best or what have you I’d love to hear it.
February 8, 20197 yr Author Here’s a picture from the adventure weekend that I broke my exhaust and officially tired my suspension out. It was an amazing weekend we will be going back to these hot springs.
February 8, 20197 yr For the snorkel I’ve used the Pajero NJ NK NL snorkel on my L series. With some sand and a heat gun I was able to bend the elbows back to meet the A pillar and still look tops. I’m not 100% sure how it would look on the MY body though. Here’s mine for comparison, my edges are squarer than the MY. I’ve properly used it once with the bow wave water 3/4 of the way up the bonnet Cheers Bennie
February 17, 20197 yr Author Little update finally got around to cleaning up the hubs and knuckles and spraying them to help against rust today because it was somewhat decent out. Also started putting the new struts together trying to get the ball rolling on the suspension stuff I’m doing so I can be done with it and focus on the EJ swap that’s also approaching! I’m waiting on brake lines and brakes and seals and bearings right now because once I got in there and tore everything apart I realized that all of that needed to be replaced or was close to needing it so might as well do it while I’m there right? That’s just how my mind works anyways might as well spend a little more and take the little bit more time if you can and do it once and do it right.
