steve56 Posted April 18, 2019 Share Posted April 18, 2019 Doing a Jdm 2.0 swap into ej2.5 Impreza. When ignition is on, there's a continuous buzzing noise from coming from under the hood. The noise is supposed to stop a few seconds after the ignition is left on. Sound like the fuel pump isn't shutting off. Any ideas. Quote Link to comment Share on other sites More sharing options...
jonathan909 Posted April 18, 2019 Share Posted April 18, 2019 The fuel pump is in the tank, so it's not going to sound like it's under the hood. I suggest you lift the hood and localize the buzz. Quote Link to comment Share on other sites More sharing options...
steve56 Posted April 18, 2019 Author Share Posted April 18, 2019 Good point, but I'm pretty sure I've heard that noise on previous engine swaps and it has something to do with the fuel pump priming. Quote Link to comment Share on other sites More sharing options...
jonathan909 Posted April 18, 2019 Share Posted April 18, 2019 (edited) You still need to lift the hood and localize it. To the fuse/relay box, perhaps? Edited April 18, 2019 by jonathan909 Quote Link to comment Share on other sites More sharing options...
Suzam Posted April 18, 2019 Share Posted April 18, 2019 Anti-lock brake pump? Quote Link to comment Share on other sites More sharing options...
steve56 Posted April 18, 2019 Author Share Posted April 18, 2019 (edited) The noise is coming from inside the throttle body. When I open the throttle plate the noise gets louder. Also engine is idling at really high at startup. Edited April 18, 2019 by steve56 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 18, 2019 Share Posted April 18, 2019 IACV, try a search, I've read of this but do not recall specifics. Quote Link to comment Share on other sites More sharing options...
