Lairdafloat Posted May 20, 2019 Share Posted May 20, 2019 Folks, Brand new here. Found the site by accident while looking for repair / replace info for Subaru Forester CV joints. Hoping maybe I could lube them up and save my wife some dough. I found an old thread about reversing the axles to put the load on the other bearing face that normally doesn't see the high forces. It sounded promising but I couldn't connect to the links from back in 2010 or whenever it was. Is this a valid 'fix' for a 2010 Forester 2.5? I'm reasonably capable with tools and would undertake it if there is some supporting evidence... Thanks for your feedback. Sorry I couldn't locate it in earlier questions. Probably didn't go back far enough! Best, Rob Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 20, 2019 Share Posted May 20, 2019 even 2010, axles are interchangeable AFAIK. One part number for front axle. 1 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 20, 2019 Share Posted May 20, 2019 Should work. Get new boots, grease, and clamps from Subaru. GD 1 Quote Link to comment Share on other sites More sharing options...
el_freddo Posted May 20, 2019 Share Posted May 20, 2019 Get a CV band tool if you don’t already have one Cheers Bennie 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 20, 2019 Share Posted May 20, 2019 you might consider grabbing an extra coupla bands. I discovered it's easy to break one if you've never used the tool before....... Quote Link to comment Share on other sites More sharing options...
Lairdafloat Posted May 21, 2019 Author Share Posted May 21, 2019 Just wanted to thank you all for your feedback. Gonna give it a go! Keep 'em rollin'! Quote Link to comment Share on other sites More sharing options...
Numbchux Posted May 21, 2019 Share Posted May 21, 2019 It's an interesting theory. But to me, it seems that if the surfaces in the joint really are that worn, it's going to be a problem either way. That said, I've brought some really troublesome joints back to life with new boots and grease. I've never bothered to swap side to side. I just re-boot originals. Quote Link to comment Share on other sites More sharing options...
