ontherun987 Posted May 22, 2019 Share Posted May 22, 2019 I just finished my weber install. it ran great for 4 minutes , then quit suddenly. I couldn't get it to start again, I thought the choke open and killed it. After playing with it for awhile checking fuel and spark, I noticed this. Awesome more fun coming right up Quote Link to comment Share on other sites More sharing options...
Steptoe Posted May 22, 2019 Share Posted May 22, 2019 This is where coincidence makes it tricky to diagnose online until you post up pictures Ever replaced that timing belt before? Quote Link to comment Share on other sites More sharing options...
ontherun987 Posted May 22, 2019 Author Share Posted May 22, 2019 17 minutes ago, Steptoe said: This is where coincidence makes it tricky to diagnose online until you post up pictures Ever replaced that timing belt before? Nope, but I have seen milesfox's videos on it Quote Link to comment Share on other sites More sharing options...
Subarule Posted May 22, 2019 Share Posted May 22, 2019 Oops. That Weber is so powerful it blew the belt right off. 1 Quote Link to comment Share on other sites More sharing options...
ontherun987 Posted May 23, 2019 Author Share Posted May 23, 2019 (edited) What brand of timing belts should I buy, are these ok? Can I just replace the belt or do I need to do the whole set? https://www.ebay.com/itm/For-85-94-1-8L-SUBARU-1800-GL-Loyale-RX-XT-NON-TUR-TURBO-TIMING-BELT-KIT-EA82T/400176384460?fits=Model%3AGL|Make%3ASubaru&epid=20003000648&hash=item5d2c5f09cc:g:fs0AAOSwEppUNE~z Edited May 23, 2019 by ontherun987 Quote Link to comment Share on other sites More sharing options...
Mack Truck Posted May 23, 2019 Share Posted May 23, 2019 how long ago did u replace the idler and tensioner pullys. id for sure do both belts Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 23, 2019 Share Posted May 23, 2019 47 minutes ago, ontherun987 said: What brand of timing belts should I buy... Gates original, or Subaru Original are your best bet... Always change both timin' belts at the same time, if one fails, the other probably soon will do the same. Tensioners and pulleys also must be changed altogether. Gates TCK-299 is the ideal timing Kit for the EA82... Kind Regards. Quote Link to comment Share on other sites More sharing options...
ontherun987 Posted May 23, 2019 Author Share Posted May 23, 2019 58 minutes ago, Mack Truck said: how long ago did u replace the idler and tensioner pullys. id for sure do both belts It was done 20,000 before I got the car 8 years ago. I have put 12,000 on it since. Quote Link to comment Share on other sites More sharing options...
FerGloyale Posted May 23, 2019 Share Posted May 23, 2019 1 hour ago, ontherun987 said: What brand of timing belts should I buy, are these ok? Can I just replace the belt or do I need to do the whole set? Mitsuboshi is best. NTN, NSK or Koyo for the rollers/tensioners. Paraut, Atsugi or other japanese make for water pump. You need to get inside and figure why it snapped. It's usually one of the idlers, tensioners, or the fault of excessive oil and coolant soaking from leaks. It's possible to do the bare minimum and get back on the road. My guess is the lower cogged roller seized. It's the most usual suspect for an otherwise decent looking belt to break. Full job would be Belts, Tensioners, Idler roller, Cam seals and Cam cap large O-rings, Crank Seal. Also Oil pump shaft seal, O-ring, and "mickey mouse" formed gasket. Quote Link to comment Share on other sites More sharing options...
Steptoe Posted May 23, 2019 Share Posted May 23, 2019 (edited) An 8 year+ belt As pic looks you got belt off without removing stuff like covers. No covers? Exposes belts to more elements to deal with for reliability. And HELLO Jeszek ! Edited May 23, 2019 by Steptoe Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 27, 2019 Share Posted May 27, 2019 On 5/23/2019 at 12:14 AM, Steptoe said: ... And HELLO Jeszek ! Hello! https://www.amazon.com/Gates-TCK299-Timing-Belt-Component/dp/B000C2UL5U Quote Link to comment Share on other sites More sharing options...
