Rooster2 Posted June 19, 2019 Share Posted June 19, 2019 Wife's 98 OBW with '95 2.2 motor just quit suddenly while driving slow at 20 mph. Motor was not over heating, or low on oil. Made no strange noises, when motor died. The motor cranks with an odd lope, suggesting compression down on one or two cylinders. Timing belt is in place, and turns when motor cranked. Occasionally, motor will back fire once when being cranked. Am wondering if something is wrong with the valves?? Anyone any thoughts or suggestions...........Thanks!! Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 19, 2019 Share Posted June 19, 2019 timing likely slipped. less likely, stuck or broken valve. find a diagram/pics on-line for your engine, bring the crank around to the timing belt install mark, check the cams' timing - double check with a tooth count, also found on-line. Quote Link to comment Share on other sites More sharing options...
heartless Posted June 19, 2019 Share Posted June 19, 2019 http://jdmfsm.info/Auto/Japan/Subaru/Legacy_Outback/1995/ here ya go - should have all the info you need. I also suspecting jumped/slipped timing. Nothing to freak out about with that year engine, tho Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 19, 2019 Share Posted June 19, 2019 I reckon it’s a cam belt issue - failed bearing on an idler pulley or failed tensioner (rare though). I’ve had it happen before, but mine was due to the engine being submerged over the cam area for several minutes. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted June 19, 2019 Author Share Posted June 19, 2019 Thanks guys for the advise. I appreciate it. Will check timing. 1 Quote Link to comment Share on other sites More sharing options...
john in KY Posted June 19, 2019 Share Posted June 19, 2019 Don't overlook checking for spark/fuel. The basics. 2 Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted June 27, 2019 Author Share Posted June 27, 2019 will do. Quote Link to comment Share on other sites More sharing options...
