David C Posted July 4, 2004 Share Posted July 4, 2004 What are some of the, most bang for the buck ,ways to increase the power output of an ea82? Thanks Quote Link to comment Share on other sites More sharing options...
86subaru Posted July 4, 2004 Share Posted July 4, 2004 ngk plugs, acell coil, cut out bottom of air box and run a k-n filter , gap your plugs at at .45 , 2 inch pipe from the cat back ,turbo muffler , no center cat , if you have a turbo motor , i call it the big football cat cut it out and run 2 in pipe back , there might be a few more like bumping up your timming , Quote Link to comment Share on other sites More sharing options...
86subaru Posted July 4, 2004 Share Posted July 4, 2004 by doing all this on my turbo full time 4wd a/t wagon it get 23-24 mpg city, 28-29 hi way , but the hp increase was great , and the motor runs cooler Quote Link to comment Share on other sites More sharing options...
Myxalplyx Posted July 4, 2004 Share Posted July 4, 2004 What are some of the, most bang for the buck ,ways to increase the power output of an ea82? Thanks http://www.ultimatesubaru.org/80s/ea-performance-page/subaru-ea-performance.html Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 4, 2004 Share Posted July 4, 2004 exhaust! 2 inch off the stock y pipe. mine has 2 1/4 cherry bomb off the y-pipe, and 3 inch after that. MEAN! Quote Link to comment Share on other sites More sharing options...
David C Posted July 5, 2004 Author Share Posted July 5, 2004 ngk plugs, acell coil, cut out bottom of air box and run a k-n filter , gap your plugs at at .45 , 2 inch pipe from the cat back ,turbo muffler , no center cat , if you have a turbo motor , i call it the big football cat cut it out and run 2 in pipe back , there might be a few more like bumping up your timming , Do you know the part no. or type of NGK plug to run? Quote Link to comment Share on other sites More sharing options...
oobnuker Posted July 5, 2004 Share Posted July 5, 2004 Do you know the part no. or type of NGK plug to run? I don't know off the top of my head, but most good parts stores should be able to tell you the OEM plugs for any given make and model. Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted July 5, 2004 Share Posted July 5, 2004 http://ngksparkplugs.com/ http://ngksparkplugs.com/techinfo/spark_plugs/faq/index.asp?nav=31200&country=US Quote Link to comment Share on other sites More sharing options...
