Zoltan Posted July 7, 2019 Share Posted July 7, 2019 I was thinking about put a JDM EJ20 SOHC non turbo motor into a 1998 Outback that has the factory USDM EJ25 DOCH motor. Can I swap the intake manifolds, like you could, on a USDM SOHC EJ25? If so then has anyone done this and what (if any) are the differences in the two swaps? Thank you for taking the time to read this. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 7, 2019 Share Posted July 7, 2019 No, your intake manifold is a different bolt pattern and won’t bolt up. Quote Link to comment Share on other sites More sharing options...
matt167 Posted July 7, 2019 Share Posted July 7, 2019 That depends. The EJ20E motor will work with an EJ22E manifold and wiring harness. But EJ20E is almost non existant anymore. Quote Link to comment Share on other sites More sharing options...
Zoltan Posted July 7, 2019 Author Share Posted July 7, 2019 I had a feeling it would not work. OK thanks Quote Link to comment Share on other sites More sharing options...
Zoltan Posted July 7, 2019 Author Share Posted July 7, 2019 I should have specified that I am looking at a EJ203 non turbo JDM from Japan Direct in Ontario Canada. Quote Link to comment Share on other sites More sharing options...
wtdash Posted July 8, 2019 Share Posted July 8, 2019 (edited) Per this: https://en.wikipedia.org/wiki/Subaru_EJ_engine The EJ203 is Phase 2 / II engine. You'd need a Phase 1 / I engine. So, your IM won't fit regardless. Easiest swap is the '95-98 USDM EJ22e. It's been covered on here a lot. There is a Phase 1 JDM EJ20D DOHC (NOT the EJ20G/K/R turbo versions), listed in that link too, which should work w/your IM, but not sure those were ever imported to the US for swaps. Not sure I've ever seen one. Edited July 12, 2019 by wtdash Quote Link to comment Share on other sites More sharing options...
Zoltan Posted July 12, 2019 Author Share Posted July 12, 2019 Ok. Thanks for the input! Quote Link to comment Share on other sites More sharing options...
