95 Legacy 2.2L
The tick honestly sounds like what ive heard in videos as lifter/valve tick... But it doesnt do it until warmup, which is what most experience(i think?), but for me it does it only after it has warmed up for a period of 15 or so minutes of idle, and is not noticable when driving... as in i think it only does it when idle.
no CEL, using 10w30 oil.
Yeah, the sound is consistent with what ive heard as lifter tick, it just its habits seem opposite of what most ppl say theres does... ill try an oil change and maybe some MMO here soon. im do for an oil change within a couple hundred miles :)
maybe low oil pressure? i seem to recall others mentioning tightening the screws on the back of the oil pump when doing a timing service.. if they are loose, you could be losing a little pressure, but it gets made up for when rpms are higher.
fwiw, the only time my 95 ticked was when oil was a little low, or it was due for an oil change.
  • Like 2
that is a good point, honestly sounds pretty spot on considering as the car warms up, the oil becomes more viscous and doesnt have as much pressure as cold thick oil.
My EJ22 has lifter tick when the oil is low. It’s like a built in indicator!
Lifter tick is very different to knock in sound. Tick is a higher pitched frequency than that of knock which is a much lower tone sound. And knock from a dead/dying bearing sounds like it’s deep in the engine too (which it is).
Cheers
Bennie
changed oil today, tick is still there, although more intermittently...
I will do MMO next, but im starting to lean on the screws on the oil pump as i have a small drip coming from bottom of the timing belt cover, creating a lower pressure... Driving and performance is otherwise unaffected...
Sound is towards the back of the right side head, facing the car.
If the screws on the oil pump are loose they leak internally. The drop you’re seeing is probably the crank seal leaking.
So LHS bank is making the noise. With the use of a stethoscope, you should be able to isolate the noise to the top end or the bottom end.
Cheers
Bennie
Cheers
Bennie
No stethoscope atm but i can say for sure i hear it more in the passenger Wheel Well than the top side
Edited by Jadu108
14 hours ago, GeneralDisorder said:
Replace the lifter o-rings.
is this something that would have been done part of a valve job(or should have been). My friend who gave me the car had a valve job done within the last 30-40k, maybe more like 20k ago, about 2 yrs or so
Alright. I will probably delay doing this for awhile, perhaps when i decide to do timing or something... The tick has quieted itself a bit and is less frequent so im not going to be concerned about it further.
Thanks for the input guys...
If i do this in the near future I will update what i did and if it solved the issue.
