homebrewz Posted August 19, 2019 Share Posted August 19, 2019 I have a 2003 Forester XS with 217,000 miles and a misfire code for cylinder #3 (P0303). The plugs were replaced with NGK's 7500 miles ago and the wires about 17000 miles ago with NAPA lifetime made by Belden. After looking for obvious problems (loose wires, shorts), I replaced the coil pack with a used one from a '04 Forester. The junkyard just said that the engine ran well that it came out of. When I switched out the packs, it ran better, but its still skipping occasionally and throwing the same code. I also have a small evap leak (P0442), but I doubt that's related. I decided to check the wires with a timing light. FWIW, these are the results: Original Coil: #1 Fast light, occasional skip; #2 Slow and intermitted light; #3 slow and intermittent light; #4 fast light, no skip. Junkyard Coil: #1 Fast light, occasional skip; #2 Slow and steady light, occasional skip; #3 Fast light, occasional skip; #4 Fast light, no skip. I'm wondering if I got a second bad coil pack. Also, is there any protocol for bench testing the coil pack? Quote Link to comment Share on other sites More sharing options...
3Pin Posted August 20, 2019 Share Posted August 20, 2019 lots of people say only ngk or subaru ignition wires. I would start with new good quality wires. Might be a good idea to tighten teh gas cap as much as you can or replace it to go after the p0442 code. Here is what some other sites recommend for troubleshooting: P0300 SUBARU - Random Cylinder Misfire Detected.... Possible causes - Faulty spark plug (s) - Faulty ignition coil (s) - Clogged or faulty fuel injector (s) - Intake air leak - Fuel injectors harness is open or shorted - Fuel Injectors circuit poor electrical connection - Ignition coils harness is open or shorted - Ignition coils circuit poor electrical connection - Insufficient cylinders compression - Incorrect fuel pressure... The P0300 code means that a cylinder(s) is misfiring or is randomly misfiring. Start by checking for intake leaks, intake gaskets are common caused of multi-cylinder misfiring. If no leak are found the next step is to replace the spark plugs. If the problem persist more tests needs to be done to diagnose problem,............................P0442 SUBARU - Evaporative Emission Control System Malfunction... Possible causes - Missing or loose fuel cap - Incorrect fuel filler cap used - Fuel filler cap remains open or fails to close - Foreign matter caught in fuel filler cap - EVAP canister or fuel tank leaks - EVAP system hose leaking - Fuel tank leaking... The P0442 code means that the control module has detected a small leak in the Evaporative Emission (EVAP). Loose fuel tank filler cap is the most common cause that triggers the P0442 code. Quote Link to comment Share on other sites More sharing options...
