Front diff is part of the trans.
If you need a new diff you need a trans.
Let me ask though, how was it determined it needs a new front diff.  That is extremely rare.  Other causes like broken CV axle or bad wheel bearing can make bad sounds, and mimic front diff trouble.
  • Like 1
4 hours ago, Jim P said:
It has play in the front differential. Alot of it.
Shaking the diff stub is not a test at all of diff condition.
The stub has play inside the spider gears, and the cup has play on the stub, and wiggle is normal.  they all have some play.
Did you check the backlash engagement of the teeth with a dial indicator?  Have you drained the front diff to look for chinks and large shavings?
Seen to many junked subaru's for "bad diffs" I guess to trust anything but a conclusive diagnosis.
Does the car still drive?
If there’s a lot of play I reckon you might have a collapsed diff bearing. Or a detonated auto - read on for more about that.
What colour/condition is the remaining oil like?
I’m asking as the EA82 three speed auto was notorious for leaking the auto fluid into the diff and vice versa, the pinion shaft bearing would “dry out”, collapse and destroy the front diff - often leading to a front end lockup, sometimes at speed :(
I reckon you’re up for a new auto.
Throw up some pics if you can, specifically the loose drive shaft side that’s leaking the oil ;)
Cheers
Bennie
check car-part.com for trans prices, then decide how deep into the diagnosis you want to go. Certainly not impossible for the diff to be shot, but odds are 90% axle vs 10% diff.(a very generalized statement)
If I wasn't dead-certain, I'd even consider taking the inner boots off my axles to inspect the doj before condemning a diff.
Rear diff - count how many times the rear driveshaft rotates for each wheel rotation by hand.
Front diff - i believe you can do the same thing by peaking through the diff plug at the ring and pinion teeth.  Or, if the front diff is already bad just yank the axle stubs and look through there or bash the casing open with a sledgehammer and count the R&P.
  • Like 1
