Steptoe
EJ tailshaft cut length ? In EA81 ??
OK
Whoever has done the full 'just EJ it's to an EA81 body BRAT, Brumby, wagon or sedan
Maybe not the hatch coz think it was shorter wheelbase
My first hands on looked like 50-52 mm should be removed
Now, made up a support to prop up the tailshaft as it comes out of the AWD box
Recap, if is an EJ20 and AWD 5MT out of GF8 Impreza of 99
EJ sits in the engine bay with gearbox bolted in place, gear lever shortened 60 mm, stay rod yet to be mounted to floor
Using an EA82 brace that used the automatic crossmember mounting bolts in EA82 in the EA81, spaced off floor about 14 mm, and AWD. just resting here
Now it looks like 35-40 mm is needed to be removed
Planning to grind off the lump of weld at rear yoke to see if I can pull tube off yoke, cut then weld up again
The uni is a little arthritic so if I stuff up boreal harm done
Share this post
Link to post
Hey Jono, the wagon wheelbase is 100mm shorter than the brumby from memory, and it shares the same wheel base as the hatch IIRC. Someone will have some specs hidden away somewhere. Hopefully they’ll share.
As for the cutting and welding, you’re correct - cut the weld carefully and that will “release” the tube of the tail shaft from the rear yoke flange arrangement.
Mark where you want to cut the shaft and very carefully cut it ensuring you’re cutting it square. Then when welding it, ensure the tailshaft and yoke flange are parallel to each other and go for it in sections at a time.
It’s a good idea to check that it rotates without any wobble in it before using it in the car.
We did this on a ‘78 Chrysler Lancer. Rear of the shaft isthr place for these mods - just in case the weld ever breaks you won’t be flipping the car with you in it ;)
Cheers
Bennie
Share this post
Link to post
Cogs working overtime in empty space....
If you are using 2 piece propulsion shaft and making a centre bearing mount, then mix and match EJ auto and EA82 shafts.
99% sure this is what was used in Toonga's Brumby when we fitted the AWD EJ 5spd box behind his carburettorred EJ20 SOHC setup.
Share this post
Link to post
Well got the hatch @ 2380 , 80 mm shorter than sedan
sedan & hardtop @ 2460, 80 mm longer than hatch
Wagons DL (2WD)? 2455mm and 4WD 2445mm
Brumby spec not in this manual so pulling it from Australian MV supplement booklet...2445mm
So same Brumby and 4WD EA81 wagon
Give that memory a gentle tap Bennie ;)
And Mr22B, was thinking of this, just trying not to waste cyberspace :) .Must hit FB see if Toonga recalls
Thinking centre bearing support mounts remains same so front shaft length is what changes and then suggestion is mix EA and EJ stuff too
Won't hurt me making up a dummy shaft out of useless parts. A mate when he needs my help is a welder with an invoice book when indeed help has nice saw and welding stuff
Share this post
Link to post
Yep, centre bearing stays in the same spot for the same year/models but changes for different EA and EJ models and because you do not already have a mounting spot for the centre bearing, then you just need to make up the correct length and then add the centre bearing mount afterwards
Share this post
Link to post
So I'm gonna dig a little deeper in examining wheelbase as it relates to drivelines. (Props)
There are only two lengths of wheelbase in relation to the length of the prop, body datum point lengths, suspension mount points, etc.
the actual listed length varies by 15~20 mm when you get into different weight/trim/fwd/4wd option, because the rear trailing arm torsion setup makes the wheel travel fore/aft in it swing, so depending on height, the length between front/rear wheel centerlines changes.  Hatch is anywhere from 2370~2380, and wagon/sedan/hardtop/Brat/Brumby are all 2445/2460  With the lower riding models being the latter in each set.
So when evaluating prop lengths, just think Short vs. long body wheelbase.
FSM lists length of the 2 props at 1057mm and 1136mm respectively.  Measured as "distance between joints"
  • Like 1
Share this post
Link to post
Thanks for that input
Got some inside info from a fella who had a Brumby with an EJ and AWD EJ box
Mr Sti22B knew it well
L Series gearbox end of tailshaft and K Series centre bearing
EJ rear diff end of tailshaft
And an EJ rear diffs flange on the EA82 rear diff to mate the differing bolt patterns
Only found this after hopping out 35 mm if EJ rear end tailshafts didn't I ?
The Impreza tailshafts tube thickness is just 1.6 mm !
Share this post
Link to post
I posted in the other thread i’m sure you saw. Another option is GC automatic driveshaft. My friend used it and he says The driveshaft is maybe an inch shorter than what would be ideal, but the splines on the slip yoke still have 2-3” of engagement, and the dust cover still overlaps over the seal on the tailhousing.
Share this post
Link to post
Noted. GC auto thanks. Now, not really EJ conversant, I know GC8 the sedan 93- 2000? And GF8 as wagon same era. No idea the letters assigned after gc and gf8
Share this post
Link to post
You can use an 93-07 (gc/gm/gf/gd/gg) 4eat driveshaft, they're all virtually the same length. You may have to change the pinion flange to match the driveshaft depending on what rear diff you use.
Share this post
Link to post
That's the sort of detail I needed to hear , thanks 86Bratman :)
funny , down under  a driveshaft is usually a front axle CV shaft, and your driveshaft is our tailshafts. Rear axles are rear axles
Edited by Steptoe
Share this post
Link to post
That sounds like a terrible idea, especially anywhere it rains, snows or where they salt the roads.
Share this post
Link to post
Well, an update
First in place measures looked like 50-52 mm needed to be cut out of the 99 Impreza manual tailshaft.
Leveled up the gearbox, propped up at centre bearing within 6 mm off a likely floor mount support and the cut looked closer to 35 to 40 mm. So using measure twice cut once ( thankyou Mr Harrison , woodwork 1980) I cut it at 35, cleaned up the end plug, uni and whacked it back in - bit like a press fit no one ever mentions! so hard a whack it loosened up the stuff joint!
That cut now looks like it should have been just 20 mm if the tailshaft or 15 for tight fit !
Share this post
Link to post
That's why I specifically used the 4eat impreza shaft. It's about 50mm shorter than the manual version.
Edited by 86BRATMAN
Share this post
Link to post
It MUST be the impreza unit, not the liberty/legacy auto unit?
Cheers
Bennie
Share this post
Link to post
Correct, the legacy/liberty driveshaft/tailshaft is a minimum of 5"/127mm longer than the impreza due to the difference in wheelbase.
  • Thanks 1
Share this post
Link to post
1 hour ago, Steptoe said:
Wonder if Forester tailshafts same or different to Imps And Libacys?
Same platform so they should be the same unless the lift is built into the centre bearing mount.
Cheers
Bennie
Share this post
Link to post
The carrier bearing is indeed different on the forester, the suspension lift is countered by a drivetrain drop or roughly one inch (25mm). Most models they can be changed out with for non lifted version, I can't say for sure on those though.
Share this post
Link to post
Ok
My donor GF8, 1999 wagon and it's sedan sister have wheelbase of 2520
The foz of same year is wheelbase of 2525
Liberty sedan 2630
Outback 2650
Share this post
Link to post
Create an account
Register a new account
Sign in
