Foilmonkey Posted September 9, 2019 Share Posted September 9, 2019 How can I drain fuel from the tank by jumping the fuel pump relay? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 9, 2019 Share Posted September 9, 2019 Yep. That will work. GD Quote Link to comment Share on other sites More sharing options...
lmdew Posted September 9, 2019 Share Posted September 9, 2019 If you cut the car side of the connector from the junk yard, you can hook the + and - to a battery after you have plugged in the junk yard connector under the seat or in the cargo area. Quote Link to comment Share on other sites More sharing options...
Rampage Posted September 9, 2019 Share Posted September 9, 2019 What is the vehicle? One time I used insulated alligator clips on the pump connector and wires to a cigar lighter plug. The two largest wires in that harness run the pump. Quote Link to comment Share on other sites More sharing options...
