Zoltan Posted October 20, 2019 Share Posted October 20, 2019 Something weird happened to me today. Two weeks ago I bought a 2005 Legacy EJ25 NA from someone in Trail bc. It has 181 000km (112 500 miles) and the owner was told by the Subaru Dealer that the bottom end of the motor is gone. I bought the car and took out the motor today. I had run the motor for 20 seconds to move it and it did sound like a bottom end issue. I took out the engine and when I took off the timing belt the lower cogged idler was destroyed, all the little bearings had fallen out and were at the bottom of the timing belt cover. I wonder if this means that the bottom end is fine. Of course I only came to this realization after I took off the cam and crank gears and sensors, intake manifold, clutch, flywheel, block heater, motor mounts and drained the oil, all too get ready to put on a JDM long block EJ20. So I guess my question is could this bad cogged idler been making a similar noise to a bottom end issue and be misdiagnosed by the Dealer. This really has me thinking I should put all the parts back on, and put it back in the car and start is up, but I would love another opinion. Is there any other way to see if the motor is good? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 20, 2019 Share Posted October 20, 2019 Cut open the oil filter and check for metal. Look in the pan also. Likely the cogged idler was the problem as you surmise. GD 1 Quote Link to comment Share on other sites More sharing options...
lmdew Posted October 20, 2019 Share Posted October 20, 2019 Some times Luck is with you! I"ve had a couple of these. Quote Link to comment Share on other sites More sharing options...
Zoltan Posted October 20, 2019 Author Share Posted October 20, 2019 Thanks guys, I will cut open filter to double check and then motor back in car. I will report back in a few days. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted October 21, 2019 Share Posted October 21, 2019 Make sure the valves aren’t bent. If it’s running you should be all good though. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
Zoltan Posted October 22, 2019 Author Share Posted October 22, 2019 Ok, so how do I check for bent valves. Engine is still out of car. I have cut open oil filter and all looks good. I have started to put motor back together. Just about ready to put on timing belt. Quote Link to comment Share on other sites More sharing options...
lmdew Posted October 22, 2019 Share Posted October 22, 2019 Was the timing off when you pulled the belt? If it was on or only a tooth or 2 you should be fine. Time it and then crank it over by hand. Everything feel good? You can hand crank and check for compression at each cylinder. Hand cranked compression has its limits but its a indicator. Quote Link to comment Share on other sites More sharing options...
nvu Posted October 22, 2019 Share Posted October 22, 2019 Compression test would answer the bent valve question. Throw it back on the car enough so you can hook up the starter and do a compression test on it. Quote Link to comment Share on other sites More sharing options...
Zoltan Posted October 22, 2019 Author Share Posted October 22, 2019 Ok thanks for the input it is much apprecitated. The car seemed to run fine for the 20 seconds I ran it to get it into its spot for engine removal. And the timing belt did have most of it's tension on it when I took it off, So I think it will be ok. I will time it crank it over by hand a coiple times and if she seems ok I will put it in the car and do a comp test with the motor. I will reports back in a few days. Working on another projeect for a friend that is more urgent. Again thanks for everyones input. 1 Quote Link to comment Share on other sites More sharing options...
