engine block compatibility? curiosity question
you can swap almost any EJ short blocks.
Its been years since I’ve done 00+ heads on 90s block, it’s not a common solution. I don’t recall any issues. I’ve had to use thicker headgaskets before but I don’t think it was for these swaps.
01 heads on 95 block will be low compression in addition to lower hp smaller block in a heavier vehicle.
is there a head combo that would not lower the compression and still work? i wouldent mind a little less power as long as it runs and drives reliably and possibly retain the non interference bit if possible. its mainly a thoght for now as my 2.5 still runs but my 2.2 block was one of the quietest subaru engines ive ever heard. it had no internal knocks or piston slap sounds.
With that block/head combo you’ll more than likely lose the non interference “feature”.
That’s nothing to be scared of - just do your timing belt kit in the given intervals and use a quality kit.
The 2.5 heads on a 2.2 block will create that funny mushroom combustion chamber to cylinder wall shape. I don’t fully understand why it’s an issue though.
Cheers
Bennie
If you’re willing to do a block swap I’d knurl or replace the pistons in the EJ25 and keep that instead of swapping blocks.
  • Like 1
