Lifted glwagon
I might have a blown fuse?
So I was driving in my 88gl wagon. It has power windows and smoke started coming from under my drivers door pannel so I pulled over and took off the pannel and no more smoke. So I put it all back together and my windows wont work now. Also since then I hear a soft click from my passemger side and the battery gauge drops significantly and then a louder click right after and the battery gauge goes back up?? The clicking happens about every 10 seconds, Any ideas??
Share this post
Link to post
Sounds like it could be a short somewhere. That would cause the smoke and yes most likely end up with a blown fuse. Check for any wires that are cut, or have plastic missing. Also any wires that could be rubbing up against sharp metal edges.  Just use some electrical tape to cover open ends that you find, and check fuses for windows and others.
Share this post
Link to post
The cyclic clicking thing sounds like a thermal trip circuit breaker cycling against a short circuit.  Got to find out the cause and stop it before it starts fire, or causes more damage.
Share this post
Link to post
Since you had smoke, there should be visible damage - melted insulation, singed, corroded connectors, etc.  Have to get in there and look closely.
Share this post
Link to post
That cyclic clicking also sounds like the power window circuits that will click and try to cut out if the window up down buttons are held down on beyond task completed.
Dave mentions thermal load, I don't know if power windows use thermal load or what
Were you using power window just before smoke started?
Maybe passenger side clicking has a stuck switch, but to cause driver side to smoke ???
How is the applicable fuse?
A mate called me yesterday with dead windows and in a panic, looking for a switch. Windows you say, not just one?
He found a blown fuse. Whether it keeps blowing a fuse I don't know
Share this post
Link to post
Thanks everyone for the advice, yes I was using the window right before it happened, I'm going to check all my connections closer tomorrow and my fuses, I'm pretty sure I know where its coming from, ill keep u guys updated, thanks again.
Share this post
Link to post
shorted wire in the door wiring.
Circuit breaker and control box under passenger seat might be smoked, but circuit breaker is cutting out.......that's the gauge dropping and coming back up as the breaker cuts out.
I'd check the heavy red wire that goes from a junction under passenger side foot carpet out ot hte doors.  There is a crimp junction with 5 red wires collared in brass.  Check that too for corrosion and re-wrap it with tape.  trace that wire up intot eh door loom to find the short.
If all doesn't return to normal after that, then replace control unit under pass seat.
  • Like 1
Share this post
Link to post
Possibly, on these old cars there can be a few that are hidden and waiting to short, good job chasing that one down and repairing it. Have you taken off the driver's side door and looked to see if you could find the smoke origin yet?
Share this post
Link to post
If you know where the fuse or breaker  is for that circuit, you can pull it, and jump It with a brake light bulb.  If there is a short, or low resistance path, the light will light, and you can go poking and wiggling wires, pulling down stream connectors,  etc. Without risking more damage, or blowing a bunch of fuses.
Share this post
Link to post
I took off the pannel for the divers side and the motor smells smoked but I didnt take it out to see, tomorrow im gonna pull all the carpet and seats out to access everything easier and just start unplugging connectors until it stops blowing fuses n then I'll see if I can narrow it down after that
Share this post
Link to post
Create an account
Register a new account
Sign in
