nelstomlinson Posted January 24, 2020 Share Posted January 24, 2020 I have a '99 Legacy Outback wagon and a 2001 four-door Impreza, both with blown head gaskets. The Impreza is smashed on the passenger side, really not worth fixing, the Legacy has no title, really not worth fixing. I also have a 2002 Outback wagon and a pair of '96 Legacy wagons, one an Outback and one not. The two junkers are going to get stripped and go to the junkyard. I'll keep what I can use, and sell what I cannot. That leads to my questions: Will the front clip from the '99 bolt onto either of the '96s? I don't care about changing the appearance, but will it bolt on? Same questions about the doors, and other body parts. Similarly, will any of the Impreza body parts bolt onto the 2002? Again, if they physically fit, I don't care about appearance. The compatibility of the mechanical stuff I can figure out, pretty much, from the Rock Auto catalog and from help you all have given me earlier. Thanks! Quote Link to comment Share on other sites More sharing options...
Numbchux Posted January 24, 2020 Share Posted January 24, 2020 96 and 99 Legacy/Outback is the same body style. Everything can be used on your '96s. I wouldn't throw that away if you're trying to keep those '96s going. '01 won't help you much. Some mechanical stuff, but that's it. Quote Link to comment Share on other sites More sharing options...
nelstomlinson Posted January 24, 2020 Author Share Posted January 24, 2020 Thanks! I'll keep a bunch of the '99 body panels, in case of future wrecks in the '96s. Quote Link to comment Share on other sites More sharing options...
3Pin Posted January 25, 2020 Share Posted January 25, 2020 (edited) the 02 engine and trans is worth transplanting if it was not overheated. Edited January 25, 2020 by 3Pin grammer Quote Link to comment Share on other sites More sharing options...
nelstomlinson Posted January 27, 2020 Author Share Posted January 27, 2020 3pin, the '02 is a daily driver, looking pretty solid so far. You probably meant the '01? I don't think it got badly over heated. I've had American engines get much hotter with no harm, but they weren't recycled beer cans, either. I do plan to tear into that engine someday, and if the crank isn't scored, it'll get new head gaskets and go on sale in the local Craigslist. It's a 2.2L, and the '02 is a 2.5L, so I don't think there will be much that interchanges besides stuff like the alternator. The two ''96s are both excellent machines. The one with an automatic I've had since it was a year old - bought from a dealer it as a high-mileage program car. That's the closest I've ever come to buying a new car. The one with a manual I bought cheap last year from a mechanic who was tired of working on it. It looks as if it's going to be a good one. I think the '99s manual trans will be a spare for that one? I'll eventually tear apart the DOHC 2.5L in the '99, too. That one had a rod knock before it stopped running, so it's probably going to be scrap, but I'll check. Some day I hope to wean my wife off these teeny-tiny go carts and get her into a diesel truck, but until I have the right truck built for her, these little subies are fun to drive and not too bad to keep running! Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 28, 2020 Share Posted January 28, 2020 Subaru's are like legos, which is nice. You will run into the scrap rule. As soon as you scrap it, a week later you or someone you can help will need it. But you can't keep everything. Quote Link to comment Share on other sites More sharing options...
nelstomlinson Posted January 28, 2020 Author Share Posted January 28, 2020 Imdew, I have 16 acres. I suppose I could drag these off into a corner and forget about them until I need something. I'd just rather not fill the place with junk. I'll probably build a shed for old parts, and stuff it full of doors and fenders and blocks and gear boxes. Quote Link to comment Share on other sites More sharing options...
