Can someone tell me where I can get a ignition transistor or is it possible to bye pass it. On a 90 Loyale
1 hour ago, Cormfra said:
Okay so now both eyelets are reading 12 ish.          But that when it’s on the coil.
Right, it will. That is because the coil is made of wire.
Your picture showed the wires NOT connected to the coil, otherwise I would have said disconnect them.
  • Like 1
  • 4 weeks later...
On 2/19/2020 at 8:12 AM, Ionstorm66 said:
F44 plugs  into he round connector .F43 into the transistor.
The ring terminal connected to the round plug goes to coil negative.
1990 wire colours may vary a little from the 1989 diagrams shown.
17 hours ago, Cormfra said:
Yes it has two wires
so what are you saying I should do
Plug the transistor in.
Hook the eyelets up.
Forget about mystery wires
Drive your car.
Might help to go back o the wrecker you got the transistor from and inspect the donors wiring..
I don`t have a SPFI car handy to look at.
