Can someone tell me where I can get a ignition transistor or is it possible to bye pass it. On a 90 Loyale
Okay so it should spark if there voltage on there side of the ignition coil correct and what would cause it to not spark even though there reading 12 on both sides.
there are other random stuff not working on the car I’m wondering could it be something with the ecu
Bad coil-does it work on another car?
Or more likely,no connection to ground thru the transistor.
Maybe no ignition pulses from the ECU on the WY wire to the transistor plug.(you need a LED style test light to see these)
You never said if there were any trouble codes.
  • 1 month later...
