john in KY Posted February 28, 2020 Share Posted February 28, 2020 Just noticed/discovered coolant collecting on the right rear side of the engine. Fairly sufficient leak. Dripping down on the motor mount. At a lose at what is the source. Can't see any coolant hoses on that side of the engine. Is there one for the throttle body? Is there a temp sensor in the area? Quote Link to comment Share on other sites More sharing options...
john in KY Posted February 28, 2020 Author Share Posted February 28, 2020 Discovered a coolant line that side of the engine and decide to just replace everything over there since the intake manifold has to be pulled. What is a good online Subaru dealer? Quote Link to comment Share on other sites More sharing options...
Numbchux Posted February 28, 2020 Share Posted February 28, 2020 (edited) Yep, there's a steel line under the intake manifold, with a little rubber hose up to the throttle body, that's likely your culprit. Can be capped off or bypassed. I love Toyotapartsdeal.com, and they have a Subaru counterpart (www.subarupartsdeal.com) Edited March 2, 2020 by Numbchux 1 Quote Link to comment Share on other sites More sharing options...
forester2002s Posted February 28, 2020 Share Posted February 28, 2020 (edited) The link above just goes around in a circle and ends up back here on the forum. Try this one: http://www.subarupartsdeal.com EDIT: FYI, when I google SubaruPartsDeal, it appears that they are owned by Genuine Parts Giant, Inc., which supplies parts for all types of cars. Edited February 28, 2020 by forester2002s Quote Link to comment Share on other sites More sharing options...
brus brother Posted February 29, 2020 Share Posted February 29, 2020 subarupartsforyou.com Quote Link to comment Share on other sites More sharing options...
john in KY Posted February 29, 2020 Author Share Posted February 29, 2020 Thanks for the links. Decided to bit the bullet and went and ordered all new hoses. Figured why not since the intake needs pulled. Quote Link to comment Share on other sites More sharing options...
john in KY Posted March 2, 2020 Author Share Posted March 2, 2020 On 2/28/2020 at 4:43 PM, Numbchux said: Yep, there's a steel line under the intake manifold, with a little rubber hose up to the throttle body, that's likely your culprit. Can be capped off or bypassed. I love Toyotapartsdeal.com, and they have a Subaru counterpart (www.subarupartsdeal.com) You nailed it. Took a closer look this morning with the "air tube" removed and noticed one of the hose clamps was installed wrong. My fault when I pulled the engine 2 years ago to correct another one of my screw ups. Took the wife out for dinner and put 60 miles on the engine and no leak. 1 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 2, 2020 Share Posted March 2, 2020 19 minutes ago, john in KY said: You nailed it. Took a closer look this morning with the "air tube" removed and noticed one of the hose clamps was installed wrong. My fault when I pulled the engine 2 years ago to correct another one of my screw ups. Took the wife out for dinner and put 60 miles on the engine and no leak. Awesome good to hear john. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted March 2, 2020 Share Posted March 2, 2020 On 2/28/2020 at 5:13 PM, forester2002s said: The link above just goes around in a circle and ends up back here on the forum. Try this one: http://www.subarupartsdeal.com EDIT: FYI, when I google SubaruPartsDeal, it appears that they are owned by Genuine Parts Giant, Inc., which supplies parts for all types of cars. Whoops. Tried to just add [url ] tags....fixed now. Yes, it's the same company. I haven't bought Subaru parts there, but I've bought others. I use their website all the time, as it will actually show you if a part is discontinued. 12 hours ago, john in KY said: You nailed it. Took a closer look this morning with the "air tube" removed and noticed one of the hose clamps was installed wrong. My fault when I pulled the engine 2 years ago to correct another one of my screw ups. Took the wife out for dinner and put 60 miles on the engine and no leak. Glad it was an easy fix! Quote Link to comment Share on other sites More sharing options...
