Johnsomething Posted April 9, 2020 Share Posted April 9, 2020 So I had the 84 Brat at a friends house In his shop so I could paint it. Anyhoo I was letting it warm up Before I drove it home, after about 20 min or so the car just cut off. No stuttering or odd noise it just stopped. It has fuel. I even drained the tank and refilled it. What I don’t have is spark. I have checked and replaced the coil but that doesn’t help. (It has power). Replaced the wires the cap and rotor. The ECM is telling me that I don’t have ignition pulse. My distributor has the four wire type of pickup which I can’t seem to find anywhere. Can I replace this with a two wire set up? Or am I missing something? This was my grandfather’s car which was purchased new in 84. He can’t drive now so he gave it to my daughter. I just spent seven months rebuilding the thing, fixing 35 years of rust and some bad body work from a rear end hit and of course new paint. Thanks everyone. Quote Link to comment Share on other sites More sharing options...
Steptoe Posted April 9, 2020 Share Posted April 9, 2020 Theoretically....gosh that looks like a tidy ute.... A two pin module could work if hooked up to the correct two wires I looked at doing this for emergency spark but stumbled on version 3 of the adaptor block I was making The mounting holes of the four pin and two pin are not the same Just had a change of plan for V4 just then... A two pin may just work roughly bunged in rather than cleanly mounted Two pin will not give knock control but should allow spark to drive it 1 Quote Link to comment Share on other sites More sharing options...
Steptoe Posted April 9, 2020 Share Posted April 9, 2020 Maybe check integrity of the four pins and corresponding females. Squeeze females a little for tighter contact on the module pins Make a new post with module wanted EA81T as title 1 Quote Link to comment Share on other sites More sharing options...
Steptoe Posted April 9, 2020 Share Posted April 9, 2020 Your KCM most likely mounted between glovebox and body. They are in next to turbo model, EA82T and first series from 85 and following year share similar if not same four pin module Must be heaps of unused, unloved S1 EA82T distributors just sitting in the US. I made a wanted call but nothing much came to fruition 1 Quote Link to comment Share on other sites More sharing options...
Steptoe Posted April 9, 2020 Share Posted April 9, 2020 EA82T S1 are mounted on copper heatsink spacers When new modules were available aftermarket, to hey we're claimed to be more heat protected Been tossing whether to add more copper heatsinks to the underside Quote Link to comment Share on other sites More sharing options...
Johnsomething Posted April 11, 2020 Author Share Posted April 11, 2020 This car has the EA81T engine. Does anyone have a part number for the four wire ignition module? i have triple checked all the relays coils wires ect. I have correct proper power to the coil but just can’t get a spark and the ECM tells me I have no ignition pulse. Quote Link to comment Share on other sites More sharing options...
Rampage Posted April 11, 2020 Share Posted April 11, 2020 On 4/9/2020 at 12:11 AM, Johnsomething said: My distributor has the four wire type of pickup which I can’t seem to find anywhere. Does it look like one of these? I don't think I would go for the cheap one. Standard products usually work good. https://www.rockauto.com/en/catalog/subaru,1984,standard,1.6l+h4,1270325,ignition,ignition+control+module+(icm),7172 https://www.partsgeek.com/catalog/1984/subaru/dl/engine_electrical/ignition_control_unit.html Quote Link to comment Share on other sites More sharing options...
naru2 Posted April 11, 2020 Share Posted April 11, 2020 2 hours ago, Johnsomething said: This car has the EA81T engine. Does anyone have a part number for the four wire ignition module? i have triple checked all the relays coils wires ect. I have correct proper power to the coil but just can’t get a spark and the ECM tells me I have no ignition pulse. 491468711 They have been NLA for a while. 1 Quote Link to comment Share on other sites More sharing options...
naru2 Posted April 11, 2020 Share Posted April 11, 2020 Except for here https://www.rockauto.com/en/moreinfo.php?pk=28389&cc=1267736&jsn=348 Quote Link to comment Share on other sites More sharing options...
Steptoe Posted April 12, 2020 Share Posted April 12, 2020 Man, been through this with a few suppliers in the US by power of internet. Must be a hoard of them waiting to be found in an old parts bin owned by a guy yet to discover, or care about the interweb. If you get a reco one, likely to have original module not new Quote Link to comment Share on other sites More sharing options...
Scoby4wd Posted April 13, 2020 Share Posted April 13, 2020 I am parting out an EA81T car that I did see running before I started stripping it (too rusty to save). I can pull this part and sell if you are interested. Quote Link to comment Share on other sites More sharing options...
