Eriksund Posted May 13, 2020 Share Posted May 13, 2020 (edited) Ok... Just got my solid lifter ea81 back from the builder and he put an RV cam in it. I've got a Weber 32/36 and here's my question... Has anyone run this set up. If so, did you have to re-jet the Weber 32/36? It's a lot harder than I thought to get the idle mixture right... Still working on it actually.. I know it's all going to change after the engines broken in... Does anyone have jet numbers for the main and secondaries? Plugs look ok, but a little on the lean side.. I would prefer to run a little rich than lean ..... Any help would be greatly appreciated... Edited May 13, 2020 by Eriksund Quote Link to comment Share on other sites More sharing options...
Eriksund Posted May 24, 2020 Author Share Posted May 24, 2020 Ok... With the help of general disorder I got it figured out. I opened up the secondary throttle plate enough to back out my fast idle screw to where there is no ported vacuum at idle... Timed to 16btdc... Runs way better... Quote Link to comment Share on other sites More sharing options...
