homebrewz Posted June 21, 2020 Share Posted June 21, 2020 I have a 2003 Forester XS and the sunroof will not open. I removed the glass and with the glass off, the mechanism works with no problem. However, with the glass installed the sunroof will only open about half an inch. I think there might something obstructing the glass at the back end, closest to the rear of the car, but I can't figure out what it could be. The sunroof was stuck partly open last time it worked and I had to gently coax it back into position and since then it won't open. I'm wondering if this is a common problem with a simple fix, or perhaps the electric motor is worn out to the point where it won't move the glass. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 21, 2020 Share Posted June 21, 2020 Likely will have to replace the entire assembly. They are cheap plastic and cable driven. When they wear out they are garbage. Used is not a good option and they sell no repair parts. Get a new sunroof assembly from the dealer while you still might be able to. GD Quote Link to comment Share on other sites More sharing options...
homebrewz Posted June 22, 2020 Author Share Posted June 22, 2020 It's getting hung up when the glass dips down to be retracted into the roof. The glass seemed to want to move slightly so I loosened the nuts and gently pushed it. I was able to open the sunroof completely, but it still gets hung up at that point when it reopens. I was hoping it was just an alignment problem, but perhaps the motor is too weak to fully retract the glass? I've read where someone replaced the motor brushes and got it working again. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 22, 2020 Share Posted June 22, 2020 You can buy the motor separate. That's the only part you can get independently. GD Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 22, 2020 Share Posted June 22, 2020 I’ve replaced entire outback sunroof assemblies with used for $75, easy, and lasted years with no failures. Never done a Forester. It may be that not many people deal with micromanaging For sunroofs, wouldn’t be surprised if you get very limited feedback on diagnosing and repairing the unit. Quote Link to comment Share on other sites More sharing options...
homebrewz Posted June 22, 2020 Author Share Posted June 22, 2020 Thanks. At this point I'm wondering if its the motor getting weak and not being able to retract the sunroof. I also took apart the passenger door yesterday to lubricate the window track and it didn't make a difference in performance. The window motors on these vehicles seem to get weak with age and then stop working. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 27, 2020 Share Posted June 27, 2020 The door window motor transmissions rust to the point of seizing. It's a known issue and lubricating the tracks won't fix the transmission. GD 1 Quote Link to comment Share on other sites More sharing options...
ranzerox Posted January 17, 2022 Share Posted January 17, 2022 @homebrewz, I have the same problem and I believe too that these window motors get weak. I rebuilt my sunroof motor with not different result. I'm about to replace it with a new motor. Quote Link to comment Share on other sites More sharing options...
ranzerox Posted January 17, 2022 Share Posted January 17, 2022 I cleaned my motor and it still does not close all the way. It's slow and it stop right before it lifts up to meet the height of the actual rooftop. Do you think replacing the motor will help? I was able to force it close by have someone keep the finger on the button while I pulled the sunroof shut. Thanks Quote Link to comment Share on other sites More sharing options...
laegion Posted January 17, 2022 Share Posted January 17, 2022 I don't know about the forester but my '03 Outback has a manual crank hidden behind a small plastic cover in the ceiling. I hear it's fragile though so if the forester does have it also...beware of turning it too hard. Quote Link to comment Share on other sites More sharing options...
