glsubby Posted June 29, 2020 Share Posted June 29, 2020 I recently purchased a 1985 GL Hatchback, that at the time was running well and is in mint condition. The owner changed wires, plugs, and cap. I put a new battery in it the day after I purchased it. I drove it for about a month, no issues, running awesome. One day I hop in and it blows the #13 Ignition Coil fuse. I check all grounds (that are visible), change the IG Coil, the starter is fine. ECU is flashing Code 14, Duty Solenoids. I followed the black ground from the fuse box all the way to the IG Coil to the cap with a ground fault meter. It signals everywhere. I am at a dead end and can't decide if the ECU is bad or if its a relay...Fuse 13 powers a lot of stuff. Thanks for any advice. Quote Link to comment Share on other sites More sharing options...
Step-a-toe Posted June 29, 2020 Share Posted June 29, 2020 (edited) You followed a black ground from the fuse box? There usually no grounds at or through the fuse box, as I think E verything is positive. Not all black wires are grounds, if they have a trace colour they will likely be positive not ground. What if you disconnect ecu before next tracing 1985 Hatchback I assume is EA81 engine/ body/ Gen2 ? And you said ECU . Controls carby ? Not familiar downunder with EA81 with ecu but if error says solenoid, have you found any ? Disconnect for test next fuse, test solenoid on its own EA82 body shape Gen3 were only referred to as RXii ? Edited June 29, 2020 by Step-a-toe Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 30, 2020 Share Posted June 30, 2020 2 hours ago, Step-a-toe said: EA82 body shape Gen3 were only referred to as RXii ? The turbo AWD units were. There were also base models. We were so ripped off not getting these in Oz! I think we need more details on the vehicle. My thoughts started out as an MY hatch but then wondered if it is an L series coupe once efi was mentioned. Or is it a SPFI concerted EA81 MY hatch?? Lets get those sorted first then go from there Cheers Bennie Quote Link to comment Share on other sites More sharing options...
glsubby Posted June 30, 2020 Author Share Posted June 30, 2020 1.8L L4 SOHC 8V (1800cc). This GL is the base, AT/ECVT. 2nd Generation GL. The ECU (or it has another name) I read controls the ignition on start up and also controls the carb. 1 Quote Link to comment Share on other sites More sharing options...
glsubby Posted July 20, 2020 Author Share Posted July 20, 2020 (edited) Okay, it’s an EA81 engine, L series hatch, base. I went through the dash and carpet and found some exposed wires as well as in the engine compartment. Fixed a wire from the ig coil and last night the car started and then died, also replaced a few suspicious fusible links. Did this a few times and fuse 13 was not blown. This morning, it starts for a few seconds then dies. Then it blew the fuse again. I do hear the fuel pump kick on. Relays have resistance etc. My question: could a ECM cause this? I’m at over a month on this thing. Edited July 20, 2020 by glsubby Info Quote Link to comment Share on other sites More sharing options...
el_freddo Posted July 20, 2020 Share Posted July 20, 2020 Got some pics you can share on this? Cheers Bennie Quote Link to comment Share on other sites More sharing options...
glsubby Posted July 21, 2020 Author Share Posted July 21, 2020 Okay, so after sifting through more of the wiring harness and using a 9v signal meter I now have power everywhere up until the coasting shut off solenoids. (Which the ecm says). Now I need to either rebuild them or get lucky and find one. I have no idea how to rebuild nor if it’s possible. I’ll do more research. I wish I could get rid of the emissions completely. Quote Link to comment Share on other sites More sharing options...
glsubby Posted July 21, 2020 Author Share Posted July 21, 2020 I thought this was the coasting shut off components but looking at my Haynes I’m not sure. There’s two, they sit right behind/underneath the air cleaner. Black/white and yellow/red wires. Fuse diagram says it’s connected to ignition and is always hot. Quote Link to comment Share on other sites More sharing options...
glsubby Posted July 21, 2020 Author Share Posted July 21, 2020 Nvm, they’re bowl vent vacuum valves. Quote Link to comment Share on other sites More sharing options...
glsubby Posted July 22, 2020 Author Share Posted July 22, 2020 Well, we can close this thread lol. I’m putting a Weber 32/36 on as I can’t course the valves. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
glsubby Posted August 13, 2020 Author Share Posted August 13, 2020 Okay. So I’ve learned a lot about cars and this Subaru over the last few months lol. I found the short to Ground and fixed it. The car runs. Stupid issue: I can’t for the life of me get the instrument cluster back in to where the visor can get in place. It also doesn’t sit right. Any help would be so appreciated! Quote Link to comment Share on other sites More sharing options...
glsubby Posted August 26, 2020 Author Share Posted August 26, 2020 I forgot to update, but, this has been solved. A factory wire (black that covers a white smaller gauge) going into a male/female plug. The female side’s white wire (going back into the black) was toast. thanks everyone, got the dash and interior back in. 1 Quote Link to comment Share on other sites More sharing options...
