Cranks and wont start
Edit: Issue wound up being a slipped timing belt. Thanks for the guidance. Wish my mechanic had listened rather than suggesting 450 dollars worth of parts that didnt need to be replaced.
92 Loyale, 192k on the clock. Car was driving fine for roughly 90 miles. All of a sudden, she dies and refuses to start. Checked wire from coil to distributor, spark looked yellow so coil was pulled and replaced. No change. ECU reads code 11, crank angle sensor. Distributor was pulled and replaced with a junkyard part, no change. Covers are off and belts are intact, rotor spins and timing appears correct. Mechanic advised a faulty Ignition Control Module was to blame. Contacted wrecker and they pulled what they though was that part except they called it a Ignition Control Module Igniter. Installed and no change. Not sure if that is the correct part and neither is the mechanic. I'm in the weeds and am about to end my love affair with the Loyale. Any guidance would be greatly appreciated.
Edited by Arthur Digby Sellers
New info
If it died suddenly with no other issues, it is likely an electrical problem.  If it did a little hurt dance and then died it is likely a fuel problem.
20 minutes ago, Arthur Digby Sellers said:
Died suddenly and has shown no willingness to change her tune.
Tried starting fluid in the throttle body, no change.
So, it's likely an electrical problem.  I would start at the plugs.  You may already have done this but do you have spark at the plugs ?
Edited by Dee2
I have seen weak, yellow spark and thought it not good enough as it was not blue
Not Subaru, but I was proved wrong, yellow spark, started and ran fine.
So I am assuming spfi ?
Start from basics often helps rule some things out
Have you been running covers off timing belts?
When you say timing belt position appears correct, how so?
I like to ask for comp test as step 1 after a few no goes diagnosing
Edited by Step-a-toe
Yes, SPFI.
Covers have been off the entire time I have owned the car.
I did ask that he check compression, which said he did, more on that below.
As far as the timing being correct and there being compression, this is according to the mechanic that has failed to diagnose the issue in the 13 days he has had the car, so the certitude of that information is somewhere between a soft maybe and completely worthless. He said visual inspection of the timing belt and pulleys indicated it is still timed right and he could hear that is has compression. Again, seems like a pretty low reliability way of making those determinations.
Upon a more lengthy debriefing, he informed me that there is, infact, no spark at the contion between the wire and the plug. Additionally, it sounds like he was trying to tell me he suspects the ECU is bad, and was just calling it a Ignition Control Module due to ineptitude. After a visual inspection of the ignition control module igniter that the auto wrecker sold me for 350 dollars is a coil.
Car is currently being towed to my home so that I can try my hand at it, rather than this guy throwing parts at it until something sticks.
So you have spark at the coil but not at the plug.  That would indicate a problem in your distributor.  When you get a chance open the distributor and have a looky-see to find out if anything is broken.  A failure of something inside could cause an engine to suddenly stop running.
Maybe the wire from the coil to the distributor is not seated and secure.  Check the continuity of that wire and if it is seated correctly.  Sometimes it's just a simple thing....
Edited by Dee2
add-ons.
Possible - the contact at the top center of the cap broke / went missing.  Or the infamous screw that holds the spinning contact came out.  NOTE, one version uses a screw, the other the shaft is D shaped, so this can't happen.
  • 2 weeks later...
Finally convinced the "mechanic" the T belt had slipped. Upon replacing those, issue was resolved. However, an ew issue has presented itself (seems to the de rigueur for this particular Loyale)
Car now idles inconsistently, starts fine but idle drops and dies if throttle is not applied to keep it around 1000 rpm. Put a bottle of injector cleaner in the tank and it seemed to help, issues is now intermittent rather than constant. Initially thought it might be a vacuum leak somewhere. Further research on the forum's also seems to indicate a possible ICA or TPS issue. Any guidance to help locate and resolve issue is greatly appreciated. Lmk if I should close this thread and start a new one
Glad to hear you found the problem.  If it was idling correctly before the belt slippage and the  belts were replaced, it's possible they are off by one tooth.  Double, triple  recheck positioning of cam sprockets.
  • Like 1
On 8/5/2020 at 4:16 PM, Step-a-toe said:
Yep. Start with new thread, new descriptive title
The "mechanic" impressed owner worked it out?
Didn't maintain the relationship long enough to figure it out, although by the above post, I might have to swing by and have him check the cam sprocket position. Given my history with him, finding he did a job in a way that wasnt entirely correct would not be a massive shock.
