86 Gl transmission Leak
There are seals between the transmission section and the differential section.   If they fail,  atf will end up in the diff.   The diff case will gain oil.  It is a pretty bug job to get to them, dissasemble most of the transmission to do it.
The other sneaky leak for atf is the vacuum modulator.
