Blueashtaylor Posted September 5, 2020 Share Posted September 5, 2020 My Soob has had trouble starting for the past couple weeks; I have to turn the key a couple of times before it tries to turn over. I replaced the starter, thinking that was the issue, but it didn't solve the problem. Any advice? Quote Link to comment Share on other sites More sharing options...
dirty_mech Posted September 5, 2020 Share Posted September 5, 2020 (edited) I had the same problem recently. I thought it was my starter going bad at first. Turned out my battery was failing, and it would only manifest in the mornings if I had let the car sit for a good long time, 12 hours plus. Checked the voltage and it was at 12.4. Not a whole lot below 12.6, but a good battery will read at least that much if you drove the car yesterday. Batteries don't last long; mine was hardly 3 years old. Is your battery old? Have you checked it with a multimeter? Don't forget to check for loose connections at the battery and the starter. Could also be a clutch safety switch going bad. A battery slow drain due to an electrical fault is also possible, but I've never seen one. Edited September 5, 2020 by dirty_mech Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted September 5, 2020 Share Posted September 5, 2020 Same thought.......battery is going south. You may want to clean off battery terminals to see if that helps. Also, attach battery jumper cables from another car, then try to start. If starts right up with no hesitation, then pretty good indication that the battery is bad. Quote Link to comment Share on other sites More sharing options...
Rampage Posted September 6, 2020 Share Posted September 6, 2020 On 9/4/2020 at 11:11 PM, Blueashtaylor said: My Soob has had trouble starting for the past couple weeks; I have to turn the key a couple of times before it tries to turn over. I replaced the starter, thinking that was the issue, but it didn't solve the problem. Any advice? Does it have a manual or a 3AT or 4AT transmission? The ATs have different connectors for the Inhibitor switch. And, do you have a volt meter? Quote Link to comment Share on other sites More sharing options...
john in KY Posted September 6, 2020 Share Posted September 6, 2020 My guess is adding a starter relay will solve the problem. Plenty of how to do on the net. Quote Link to comment Share on other sites More sharing options...
