NuclearDeLorean Posted September 20, 2020 Share Posted September 20, 2020 (edited) Hello all! Got a beautiful Clarion stereo to fill the hole in the dash, and had a few questions. 1) Does anyone have the wiring schematic to the harness coming from the car? Color codes? 2) Does anyone know the pinouts for this Clarion stereo? The plug matches, but from what I’m reading, that means nothing. 3) How would you set a preset? I cannot pull the tabs out like old school radios used to be. Ideas? I guess I should get it working first. But curious! I know I have the only speaker in the center of the dash, took the glovebox out and saw the plug into a shot-looking speaker. Looked White? With the radio plugged in, I have no response, but the clock in line with the wiring for the radio, works. Power is going through to the clock. Thank you! I’m again humbled by the almighty USMB! I appreciate you all. Edited September 20, 2020 by NuclearDeLorean Clarification Quote Link to comment Share on other sites More sharing options...
NuclearDeLorean Posted September 20, 2020 Author Share Posted September 20, 2020 (edited) Per the Wiring Diagram(s) which none are Brat specific, here's my guess. White- Speaker White- Other...speaker(maybe stereo?) Blue- Switched Hot Red(double)- Constant Hot RedStripe(double)- Hmm... Black- Ground Also, anyone have a photo of the plate that goes over the plastic, but under the knobs for the stereo? There were colors that matched the dash color? #18, came in Grey, Brown, and Blue. Edited September 20, 2020 by NuclearDeLorean Added a photo Quote Link to comment Share on other sites More sharing options...
moosens Posted September 20, 2020 Share Posted September 20, 2020 Time to look for a service manual. That looks like an 80’s radio. But if the plugs are the same I would try it first. Quote Link to comment Share on other sites More sharing options...
NuclearDeLorean Posted September 20, 2020 Author Share Posted September 20, 2020 (edited) I own the service manuals. Every wiring diagram does not match the color codes I have in my hand. I have three separate factory guides as well as the 81 parts guide. Out of the 15 wiring diagrams I have, none match the radio colors. i have it plugged in. No response. The radio could be a dud, I just want to make sure I have it wired correctly. L - Blue RL - Red-Blue RG - Red-Green B - Black W - White Edited September 20, 2020 by NuclearDeLorean 1 Quote Link to comment Share on other sites More sharing options...
croak Posted October 4, 2020 Share Posted October 4, 2020 (edited) Blue is stereo hot, red is headlight switch, red yellow is headlight dim. The 2 whites go to speaker. (Its possible I have the lights and dimmer backwards, but shouldn’t matter) I’ve been playing with one of these exact stereos, and guarantee this is correct. You should be able to pull the buttons to set presets, mine was a little sticky when I got it. Edited October 4, 2020 by croak Quote Link to comment Share on other sites More sharing options...
NuclearDeLorean Posted October 6, 2020 Author Share Posted October 6, 2020 I love you. Thank you! Quote Link to comment Share on other sites More sharing options...
