Starts; but let the key go to run position(dies)
Hi,
   Title says it all.....
She starts right up.....
                 Actually was sitting..... for a month.....(before today)
             turn key..... let pump pressurize.....
turn key to start....... starts right up....
let the key go to the run position.... and she dies....(cuts right out.)
                 If you hold the key in the start position.... she will continue to run......(not a good thing to do... but, ....)
    So this first appeared as an intermittent problem.......(like almost it was missing(misfire)... running on four... I mean three.. or two .. cylinders)..
But, now.......  it is not intermittent....
thanks
Micky
So I was thinking.... maybe... .ignition switch.....
 I had one out of another car....... threw it in.........  car still    dies when the key goes to the run position........
       Is there a way to bypass.....(like hot wire) bring power to the distributor.... like what if I bring a wire... from the
battery........  +........ to the coil..........+      (thinking)
(maybe the computer is bad????)   yet... I have not seen one of these ever go bad.....( car has 313k)  (corrosion???)
Schrug, Micky
Problem as early stated::::::
""turn key to start....... starts right up....
let the key go to the run position.... and she dies....(cuts right out.)""
Explained with greater detail
After the vehicle fires up..........  (as I mentioned initially)....  if I hold the key in the "start" position....(this keeps the starter engaged--- which is not good)
the vehicle will continue to run   .....(as long as I hold the key in the "START" position.....  car continues to run....Understood.....)
So this is (what we learn to do as drivers)  :::::::  is we let go of the key when it fires up.....RIGHT!... perfectly normal thing to do....(we are taught to do that as[car drivers])
and we go our merry way....... driving....
NOT THIS CAR....
This car dies...... when the key is released from the finger tips and springs  to the "RUN" position.
it is DOA.........  Might as well have turned the car off.............   The ignition system is not getting power......
                                       Am I clear enough.........??????
Thnks, Micky
There are no codes.....  well,  no lite on.....  hasn't ever been......
    Taking what you are saying...... which is to say one suspects something.... which in your case.... mentioning..
the idea that possibly when the key is released from the start position to run position..(normal starting procedure) ...  the fuel pump is not pumping....fuel anymore.......KAPUT......
      I haven't checked this... so I can't say yes.... or no.....
        but, will say that my understanding about the fuel pump is that it is powered
the same(receives it power the same way)  during start  verses the key being in run position...there is not two circuits to power the fuel pump........
But, there are two circuits to start the vehicle......  (Hence that is why the starter stops turning.... and can unmesh from the flywheel ring gear)
       BUT, your idea gives me an  idea....   which is.....  possibly to take an inductive timing light....(geeze,, if I can find where it is... haven't used it in IONS)
                    It will flash  if there is spark in the secondary circuit...(hooked up to #1 wire)....... of the ignition system....(running).....
                  and when it dies.......(??????????)   if there is no electricity to create spark.... it should just flat out.... not  light....   KAPUT......
SO..........................   In start position, holding key there  in start position..(simulating that it is running but, starter is engaged)
                          ...... inductive timing   should be lit...... (definitely)
                            THEN    let key go..........   light should drop out immediately ........( if no electricity is in secondary ignition system)
                              Any inkling of light while key is in run position indicates..... further investigation of a fuel issue.........
                                      Thoughts??
                                               what about a fuesable link.....???? is there any such thing.......
                                             seems like.....   the two circuits....     start works.......     run doesn't work.....
                                            fuseable link.......?????????????
MIcky
There is a mechanism /circuit that shuts off the fuel pump if the engine stops running.  The reason is to stop pumping fuel in theevent of an accident.   Exactly how this is done varies with the model and year and type of fuel system.
There is a seperate signal sent to this circuit while the key is in the cranking position,  otherwise no fuel would be pumped, making starting difficult.
  • Like 1
On 11/9/2020 at 5:40 PM, Step-a-toe said:
May help to add the finer details of car
Car .....as in year, engine, fuel system such as carb or Spfi, mpfi.
I have come across this problem but cannot recall what was the cause but I think it was in the ignition barrel electrical connection integrity
Yeah, So one can't entirely rule out the possibility of loss of fuel when key is turned......
So yeah, thought I put that up top..... Appologies......    92 Loyale 1.8L(SPfi)  5 speed
                                                    Ignition barrel electrical connection integrity......(I like how that sounds!)
                                    I have two of these pups that are down..(sorta DOA's...had good lives).... so I grabbed an ignition switch out of the other one...
                               It did not change anything... still have the issue....(just adding this event here.... no sure if it says anything or helps...info is info...)
                                              about I.B.E.C.I (Ignition barrel electrical connection integrity)
Micky
This sounds more like an electrical problem than a fuel problem.  If the fuel supply were cut off the engine would likely sputter for a while then die.  Sudden death seems more likely to be electrical.
Micky
Sure,but,does it work?
Does it output 12V in RUN position?
Does it output 12 volts in run position?
   I did change the ignition switch(an old one from a 91)
that was a known good switch.....   this doesn't answer your question......
Do you know what wire on the ignition switch(color) would be the one to check?
Thanks, Micky
I know on older cars that is a symptom of the ballast resister being bad. When cranking, full battery voltage is fed to the coil for a stronger spark when starting. After the ignition returns to run, the coil is powered through a ballast resister lowering the voltage at the coil as not as strong a spark is needed. So with a bad ballast resister the car will run in "start" and die in "run" key position.
Disclaimer... I dont know what car you have or if it even has a ballast resister or not.
Thanks, Micky
The big black one
No ballast resistor on a SPFI Sube.
Edited by naru2
  • 2 weeks later...
I believe that the engine runs off the battery during ignition and switches to the alternator once the key returns to the run position.  So you might check the alternator wiring for it being in place, and then the alternator.  There are also three wires that go bad in the same area.  The ground wire gets hard and goes bad where it is bolted into the chassis, just in front of the battery, causing the engine to run rough with headlights on or working any other accessory.  The wire that comes off of the bottom of the hot battery terminal wire and goes to the fusible link box, gets hard and loses it's ability to conduct electricity.  The wire that is bolted into the back of the alternator also gets hard and loses it's ability to conduct electricity, causing the engine to kill.
  • 3 weeks later...
I am bringing this post back to life...
 I got a chance to look at the car again today.......
Where I left it last. (like a month ago).. was.....   a dead battery and turn the key to start(it starts)... let go of the key(it dies)......
   SO  today I jumped the (loyale)car with the  Soobie Outback.
I wasn't expecting any results..... I didn't expect the battery to just even crank over with the cables on it........
SO what I was anticipating......... ENDED up  being TOTALLY  UNTRUE!!!!!!!!!!!!!!!!!!!!!!!
It jumped..... and I held the key(for a while in the start position... not that I thought it was relevent. to do.....     bUUUT did it anyway)
SOOOOOOOOO.....     I finally let the key go........ and the freakin' (loyale)car was running........
This motor  with  300k on her.... runs like a top...........
SOOOO  I didn't do anything..........(the idea is to drive her,,,,, her last ten to fifteen miles to the scrap yard)
I just let the car run..... and didn't fiddle with anything.....(nooooo fiddle playing,,,, not a single bit).....
(Spent the time cleaning out the car.... took the stereo out.... etc etc.....)
My point here...
                          The car warmed up beautifully.....  the idle kicked down beautifully.....
ran for about an hour....(iwas amazed).......
                               I was there when it died......Cuz it was inevitable....................................
just completely  stopped.... running............(like a heart that stops beatin'''''''')   DEAD...
Interesting..............    I tried to turn the key. to crank it....      Battery DEAD....
SOOOOOOOOO     the car ran for an hour...... ON the juice in the battery.....
the alternator was not powering the vehicle.??????or charging battery?????
I have the battery on an overnight slow charge......(deep cycle)
Alternator( I didn't look at the gauge while running....[that kinda sucks])
I will clean some connections.......( if I have to....I have another alternator.....)
I am just  scratching my head..........   If this is all part of the same problem.....
It ran fine............. where as before  it didn't even  stay running??????????
sounds like  corrosion ........... on connectors..... As stated above.... I will look at connectors at the coil.... and the alt.......
        Any thoughts...
                       Thanks, Micky
A few things that might or might not help...
The OEM alternators wear out one of the slip ring brushes by around 150,000 miles.   When it happens, the alternator just doesn't put out the amps - but it keeps the charge light off, so you don't notice until the battery is dead, or you get lucky, and see the alt light dimly flickering in the dark at idle.
The OEM alternator when everything is working well, makes enough to run the engine at idle, but not much more.  Haadlights on at idle, you are drawing some power off the battery.
Jumper cables - Most of the typical lower cost ones I've seen are made with 10AWG wire with crazy thick insulation.  They won't crank most engines without some charge in the dead battery.  The jumper cables I make are #1AWG wire.  I have jump started diesel construction equipment with them, with no battery.
The engine will run for a few good drives over 2-3 days before the battery will be too weak to start the engine.  Going by my experience, with middle grade or better batteries, biggest capacity that will fit in the space - not what the book says the car needs, and not near end of life - 5years.
If the battery discharged to the point where it couldn't run, I would expect it would gradually run crummy, till it died, not quit suddenly.
Quitting suddenly is a typical timing belt failure symptom.  Just do a check, watch the distributor rotor while someone cranks it, it should turn.
